Fiat ducato 160 multijet. engine warning light stays on
landsend
  • 1066 Answers
SOURCE: fiat ducato timingbelt problem
on the front engine pulley/harmonic balancer or in a hole on the bellhousing.
Posted on Mar 11, 2009
SOURCE: fiat ducato van, the hand brake light is always on
If you have a Ducato camper - then this is from the step of your camper being down (or the sensing switch broken) its a safety device so you don't drive with the step extended - if not a camper then sorry I can't help.
Posted on Jun 01, 2009
  • 250 Answers
SOURCE: Trouble removing the engine cover from Fiat panda 2006 diesel
i guess you got a chip then, look at the cover ithink 3 or 4, circles, fine screw driver and pop em out to see the 10mm nuts.
Posted on Aug 15, 2009
  • 432 Answers
SOURCE: loss of clutch
Call the Fiat dealer and get the parts department. Tell them whats happening and ask if they offer a stronger plunger. If they dont, call a high performance auto parts store and ask if they have a racing clutch master cylinder. If they do, go look at it and see if its the same plastic plunger. It should be a heavy duty plunger.
Posted on Sep 03, 2009
ZJLimited
  • 17970 Answers
SOURCE: please could you tell me the wiring diagram for a fiat ducato
Check HERE (need register)
Also, its possible that this Reference Guide be interesting.
Hope help with this.
Posted on Mar 23, 2010
Fiat Ducato temperatutre When putting the engine under pressure ie. going uphill the temp. needle moves from one increment below midway to one above midway, is this normal or do I have a problem
Yes that is perfectly normal and is a result of the increased load on the engine. If the engine is running to hot an warning light will come on.
Jul 10, 2017 | Fiat Cars & Trucks
How I can get fiat ducato 1997 wiring diagram?
It should be in the manual. Order one off eBay or from fiat. They do have some manuals free download on https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.docs-engine.com/pdf/1/fiat-ducato-wiring-diagram.html&ved=0ahUKEwiD-YTkmYjOAhWD8CYKHfC5C68QFghEMAo&usg=AFQjCNEx_B_q5849dTMspsEZNOOYdJEVdg&sig2=niJbFpwZaTy4XTLygqxfdQ
Jul 21, 2016 | Fiat Cars & Trucks
My 2008 fiat ducato 2.3 130 motorhome has flat spots when accelerating and the engine management light comes on and stays on,what could be causing this
dirty throttle body,blocked fuel filter,faulty throttle position sensor,faulty air flow meter or map sensor
Jun 19, 2016 | Fiat Cars & Trucks
FIAT 2007 2287CC IT SAYS 160 MULTIJET ON THE DOOR BUT I CANT FIND ANY DETAILS ON THE WEB
If Ducato 120 hp.To show your appreciation press the helpful button and follow me on fixya for more tips and info
Feb 16, 2016 | Fiat Cars & Trucks
Fiat 500 1.3 multijet diesel with fault code p0089
P0089 Fuel pressure regulator - performance problem
Mar 30, 2015 | Fiat Cars & Trucks
How can I turn off the oil light in a Fiat Ducato 150 multijet, 2012 model?
Don't drive the truck until you are sure of the oil pressure. If there is oil in your motor, next locate oil pressure sending switch and install a manual gauge and check for a reading. If you get a reading on that gauge, install a new sending unit.
Mar 08, 2015 | Fiat Cars & Trucks
Fiat ducato comrortmatic gearbox warning light comes on
the light is telling you that there is a problem in the transmission that if you continue to ignore it and not have the problem fixed will cost you big dollars . Run fault codes --- change oil and clean filter --- have the bands and clutch packs adjusted for starters as it may reveal a fault that can be fixed early for little cost.
Feb 09, 2014 | Cars & Trucks
Fiat ducato timingbelt problem
Mar 10, 2009 | Fiat Pininfarina Cars & Trucks
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
