Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1997 chevy 1500 truck starts but wont stay running
    Master:
  • 416 Answers
Ignition module
ignition switch
fuel filter
bad crank or cam sensor
Posted on Mar 26, 2015
  • 408 Answers
SOURCE: 1997 Chevy Suburban
Check the starter Solenoid.  This is a common problem and can be fixed pretty cheap.
Posted on Mar 21, 2009
centralvalle
  • 386 Answers
SOURCE: 83 chevy truck starts then dies off. wont stay running
when it shuts off is it a warm engine condition going into closed loop , no check engine light ?
Posted on Aug 04, 2009
SOURCE: My 91 chevy truck wont stay running it starts up then just dies
my 2001 silverado wont stay on. it starts up and runns for a while then starts to putt then it dies
Posted on Oct 14, 2009
vishnu369
  • 94 Answers
SOURCE: 96 chevy truck wont stay running -- it starts then
Hi
Check the battery power of the vehicle. if battery hasnt have sufficient charge give it for charging .Also check the fuel and oil levels of the truck
Thank U
Please rate me as it wil cost u just one click
Posted on Oct 30, 2009
TDISLine
  • 1874 Answers
SOURCE: 1997 Chevy Express van 1500
It's clear that you have a fuel system problem, if the engine will ignite only with starter fluid. Injectors do not spray when engine cranking, even the fuel pressure is good enough = 60 psi. Then remove the fuel rail assembly with injectors and see if they spraying fuel when another person cranking the engine. If not, check the electrical power supply of injectors & repair wires, connections, ... Also verify the Engine Control Module (ECM) output power towards injectors.
Posted on Oct 23, 2010
Wont shift into park
Check the shifter for something come loose or a damaged cable or leaver..
Aug 11, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
2003 chevy silverado 4.3 starts but wont stay running
Correct fuel pressure? EGR stuck open? IAC dirty/stuck? Throttle blade hanging open preventing IAC from working? Yune up issues?
Jul 07, 2014 | 2003 Chevrolet Silverado 1500
1997 Chevy Cheyenne won't stay started
Most likely a bad ignition switch (unless you just installed a security system) these have a history of ignition switch Failiures.
Jun 04, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
Van will start but not stay running 97 chevy venture
If it starts for 5 seconds out less, and you notice a security light on the dash, go to this link for answers. Gm are notorious for failing antitheft systems http://vatspasslockpasskeysecurityhelp.yolasite.com/
Oct 02, 2011 | 1997 Chevrolet Venture
96 chevy truck wont stay running -- it starts then dies
Hi
Thank U
Oct 30, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Sep 13, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Aug 04, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
1997 chevy 1500 wont stay runing
Ok, first, you need a new altemator. When you pulled off the battery cable with the truck running . it caused a voltage spike and fried the voltage regulator, which is internal on this particular altenator. If you want to check to see if the altenator is charging, use a volt meter.
Since it wouldn't start after you put the new altenator on, it could be one of two things, either you got a bad altenator which happens sometimes or, you have a weak battery and the altenator is tryng to charge itself to death.
Apr 10, 2009 | 1999 Chevrolet Silverado 1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
