Question about Mtd Garden
Oil in gearbox Victa 4016trx
Needing to know how to put oil in gearbox
4 Suggested Answers
  • 6 Answers
SOURCE: where is opening on for oil on the gearbox. lost lot of oil and now needs more
hi the oil filler is on the side remove the plug fill gear box till the oil runs just runs out of the hole put plug in
Posted on May 01, 2009
  • 17 Answers
SOURCE: YZ 125 04 GEARBOX OIL
Should be about 650ml, isnt it stamped on the casing somewhere?
Posted on Jun 17, 2009
  • 8404 Answers
SOURCE: gearbox oil change on a suzuki rmz 250 2010 model
Is this a 2 cycle or 4 cycle motorcycle?
I am not familiar with this model. Typically, motorcycle transmissions are lubricated with engine oil. Do you not have a owners manual for your 3 year old motorcycle? Check behind the side covers or better yet, check with your Suzuki dealer.
Thanks for your interest in FixYa.com
Posted on Mar 01, 2013
I have recently been given a Victa Catch and Release Lawnmower,but no manual. How much oil do I put in before commencing use. And How do I drain dirty oil?
Victa catch and mulsh ?
search pops these up as 4 strokes
which model and a internet search gets you its user manual
start with 600 ml oil and top up as required
try not to over fill
look for drain plug up under blades or on the side of motor
Nov 06, 2016 | Garden
Where do I open the gearbox to put in more oil?
the oil filler and level indicator are usually at the same point which is usually on the side of the gearbox. removethe plug, fill the gear box with the correct oil until the oil starts to pour back out of the plug hole. then replace the plug. (basically)
Mar 02, 2015 | Opel Cars & Trucks
How do i refill gearbox oil
We need more information. Type of Vehicle, year, is this manual transmission....etc. That being said, most "gearbox" have two 'bolt type plugs' on them. One to drain fluid out and one to put fluid in. Really need to know more about what you have.
patrick
Jan 13, 2015 | Cars & Trucks
I dont know what else to add other then the oil came out of the mixer when i moved and i do not know what type of oil to put back in it and where do i put it in to the mixer on my kitchen aid mixer
Wipe the oil off and carry on. Over time the gearbox grease breaks down and oil separates from the grease solids. Eventually the gearbox will need to be repacked with new grease. Don't worry about a drip or two in a cake, it's food grade grease so harmless.
Dec 09, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
Do i need to put gearbox oil in my roadwin aswell as engine oil
Hi the roadwin is a fourstroke engine and the gearbox is 1unit, so the engine oil lubricates the gearbox also, ( no need for gearbox oil)
Regards, paul
Mar 01, 2011 | 2007 Daelim Roadwin
Why does my van kick when i put it in reverse?
Hi, if you have a manual gearbox then the problem could be any of the following:
1. gearbox oil could be low causing the gears to bite to hard.
2. clutch could be low and need replacing.
3. gearbox or engine mounts could be worn causing the engine or box to **** when put under pressure.
4. ball joints could need replacing such as bottom ball joint and anti roll bar bushes.
you can check the oil by finding the oil level bolt on gearbox remove bolt and if oil comes out its ok if not it needs topping up.
you can check engine/gearbox mounts by getting a good hold of the top of engine and give it a hard pull and push their should be only slight play any more and some mounts may be worn.
ball joints you can check by jacking the van off the floor then use pry bar to put bushes under pressure and check for play, their should be only slight play any more and the bush will need replacing.
Now if you have auto box then the chances are the fluid is bad and needs replacing or worse case it could be that the torque converter is on its way out.
let me know how you get on or if you need further assistance ok
Jun 27, 2010 | Cars & Trucks
Where is opening on for oil on the gearbox. lost lot of oil and now needs more
Apr 24, 2009 | Volkswagen New Beetle Cars & Trucks
Oil level for Suzuki TS 185 (1989)
Drain the oil and put 750ml back into the gearbox. If your bike doesn't have a dipstick and you have good, clean oil in it, drain it into a plastic bowl then put it right back into the engine but measure it before you pour it back in. When you get 750ml in the box then look at the level in the box. That is the level to maintain.
Pleas rate this solution. Thanks!
Mar 29, 2009 | 1981 Suzuki TS 185
Gearbox
what kind of car like certain mazda you have to remove speedometer cable or sensor add gear oil untill you see oil at the bottom of the hole some gear box take heavy gear oil some motor oil 5w30 dont put to heavy oil it gonna be hard shifting when cold cheers let me know what kind of car cheers
Jan 20, 2008 | Visonik V308XT 180W x 2 Car Amp Car Audio...
Garden Logo
16 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
