Question about Dyson "Stowaway" Canister Vacuum Vacuum
Sparks at outlet - Dyson "Stowaway" Canister Vacuum Vacuum
Kirby doesn't always start when plugged in unless I jiggle the cord and then it often stops when in use.
You need a new power cord! :0) Here is a link to help with replacing it...
Jun 17, 2014 | Kirby Vacuums
Spark caused vaccum to turn off
Some vacuums have a reset button you can push. Some have a fuse in the power line that may have blown. You will have to follow the power all the way through the vacuum checking the voltage at each switch, connection, etc. I often unhook the power & neutral wires from the motor and hook up a power cord with connectors on the end directly to the motor to make sure the motor is good. You must be very knowledgable with motors, switches, electrical testing, etc. If not this repair is best left to a professional.
Mar 03, 2014 | Dirt Devil Vacuums
I had my bosch 1400 W 12 amp vacuum plugged in and it blew a fuze so I reset the home fuze box and went to plug it in and it sparked and blew the fuze right away. The plug was very hot to touch. I am...
Often if the plug or cord is a problem, it can be seen. Look carefully at the plug, are the prongs straight? Is the cord damaged where it enters the plug? Is the cord damaged where it enters the vacuum? If the plug was rotated, it is possible that the wires inside the cord may have frayed insulation and are making contact with each other.
If it is the plug or the plug end of the cord, you can get a new plug at Home Depot and replace your old one.
Also, if you have a switched outlet or switched multi outlet extension, you can shut the power to the outlets off, plug in the vacuum and turn on the switch so you are not near the plug when you plug it in to test it.
Gary
Jun 23, 2011 | Bosch 12-Amp Formula Canister Vacuum with...
When you plug in the vaccum it sparks from the outlet
If it trips the breaker, you have a short somewhere from the cord to the motor. If not, be sure to wait until it's plugged in before you turn the switch on. Turn it off before you unplug it.
Dec 30, 2010 | Electrolux Vacuums
Miele Red Star, small spark at outlet, no power to vacuum
The vacuum has a standard tube internal fuse. If you are lucky that is all it is. See the site http://www.sannerud.com/house/miele.html for instructions on how to open it up.
hope that helps
Jun 05, 2010 | Miele Red Star Bagged Canister Vacuum
This Model likes to shoot electrical sparks between the plug and wall outlet when plugging in. I'm afraid I'm going to burn out an outlet.
This sounds might hazardous! Worry less about burning out an outlet, and more about the risk of electrocuting yourself!
There's an electrical short-circuit somewhere, and the first place to look is the flex. Flex often gets damaged, usually just where it leaves the plug or where it enters the machine, especially if it's been pulled a lot. Damage is not always visible externally. I'd get it looked at by someone competent to deal with electrics. Better safe than sorry!
Feb 13, 2010 | Hoover U8311900 WindTunnel 2 Vacuum
I have only used this mop a few times because everytime I go to plug it in the outlet, there are sparks. I have tried three different outlets. Is there a recall on this??
No, but hopefully you are in warranty...1 year...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jan 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Sparks from the Kirby Motor
1. Do you think this may be the problem?
YES
2. How come it continues to rotate?
Motor armature consists of multiple coils and just some of them burned so even though it keeps spinning it does not function properly.
3. Do I need to replace the armature?
We have switch replacement instructions HERE and they will take you as far as accessing the motor. We do not have motor assembly instructions yet but if you get that far - motor is not that hard to reassemble. You may have to spend some time getting tolerance ring back in and make sure you install finger spring properly.
Good Luck
Dec 28, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Will not start again.
If the cord sparked, then it is bad and needs replaement. If it sparked at the plug end, then replace the plug.
Feb 23, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Dyson "Stowaway" Canister Vacuum Vacuum Logo
27 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
