Question about Panasonic SC-HT650 System
Reading code f61
I try to power it up and it reads a code f61 and powers back down
Pop cover plug in with med to light pressure on the heat sink press down gently and push one way just a tad , press power , see how long to shut down. do same other direction. what you should find is that the solder connections are bad and need to be redone. this is not the first pan. that has had this problem, some of there other stereos do to.
Posted on Feb 25, 2015
5 Suggested Answers
  • 4234 Answers
SOURCE: sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Posted on Apr 09, 2008
  • 4234 Answers
SOURCE: SC-HT75
The output amp pac has a problem. The F61 is indicating that the unit is in protect mode. This is a mode where the output section is shutdown to prevent further damage. Figure on $65-$95 for parts.
Dan
Posted on May 19, 2008
dunnbiker
  • 8546 Answers
SOURCE: my dvd stereo system panasonic model SA DK2 , F61
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 21, 2011
mlapres
  • 757 Answers
SOURCE: I have a panasonic blue ray player model number SA
There are two cooling fans on this unit. Fans like other motorized devices also get hot, I'm assuming that these fans have a thermal protection circuit for safety reasons.
Removing the unit chassis so that you can gain unobstructed access to both of the fans is a must. Once inside you will see that the blades and surrounding devices are coated in dust; the use of a simple commercial grade vacuum with a soft bristle brush tool will be the first step. It will be able to remove most of the gross filth.
Next, using a dry cotton swab, carefully navigate the tip of it all around all of the various electronic circuit components and pick up the most dust with it that you can.
The next thing is thorough cleaning of the fans; the dust is pasted on there pretty well you may have discovered by now. The cotton swab comes of good use there too. The fan blades are much more effective without the dust on there. Next, turn your attention to the fan blade shaft assembly where it attaches to the fan motor. Using your cotton swab and a toothbrush, get it as clean as possible. When finished with that, you will need a special lubricant that is a light weight machine oil. It is made by Liquid Wrench and is called super oil. One drop on the shaft which is immediately behind the fan blades although you can't see it, the oil will make it's way down in there, and a second drop on the bearing assembly. You will find that by searching the opposite end of the fan motor for what appears to be a small metal box, look at the rear of it and you'll see the tip end of the motor spindle. Put a drop of oil on it.
After you replace the chassis make sure that you when you return the player where you intend to operate that it always has at least 2 feet of open and unobstructed open air around it without any heat sources within that 2 feet clearance such as another heat producing AV device like an amp or a furnace duct, sleeping cat, etc....
Posted on Dec 18, 2011
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
F61? how do i fix it...................everytime i turn my panasonic sc-ak340 on i get a error code that reads f61 and then my system shuts down by itself..can this be fixed?
I've encountered that kind of problem.
f61 appear on the screen then shuts down the unit.
The very common defect is your fan, output ic (rsn series).
First check the fan if it is in good condition (disassembling the component is quite technical it need a lot of care).
sometimes the fan is full of dirt that's why it will not work properly which the system sense and uttered the unit to switch of avoid further damaged.
If you confirm that the fan is working properly I will suggest you to bring your unit to a qualified technician/service center because replacing the output i.c. is more technical.
Dec 13, 2009 | Panasonic SC-AK340 Shelf System
Code f61
the f61 code is an audio code for panasonic first make sure all connections are correct and tight for spearkes...at the base if unit has base and with connections in back of unit and are fully in to connection terminal...make sure speakers are on and not on mute ...sometimes though you may have to re strip the wires to get into connection termianl in the back of the unit if that does not work call panasonic 1-800-211-PANA(7262) for more technical support
May 15, 2009 | Panasonic Audio Players & Recorders
Error code F61
Please describe your f61 error code problem:
Aug 09, 2008 | Audio Players & Recorders
Sa-ht545 error code f61- comes up upon statrting
F61 just equal 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic IC 502.
As both said ICs get very got first remove bottom steel grill and with the power off and capacitors drained (shorted together with a low ohms resistor or leave unit powered down for a few hours) resolder the ICs legs if there are any signs of cracks aka dry solder joints.
Hope that helps.......
Jul 09, 2008 | Panasonic Audio Players & Recorders
Panasonic SA-HT740
Think I got it. Check your fan. Power it on and see if the fan spins for a few seconds and then stops. This is why mine kept giving me the F61 code and powering down. Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
So far it's working for me. Good luck!
Feb 16, 2008 | Panasonic SC-HT995W System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
Oct 09, 2007 | Sony MHC-G100 Shelf System
My Panasonic SC-A240 shuts down displaying the error f61.
Several components in the power supply maybe faulty, especially Tranisitor Q5110, Resistor R5114 and Diode D5102 on the power supply board. Check and replace these and also resolder the regulator IC's on the heatsink.
Sep 05, 2007 | Panasonic SC-AK240S Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
Panasonic SC-HT650 System Logo
108 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
