Question about 2004-2008 Ford F-150 Not For FX2 and Lariat Model Main Upper Aluminum Black AL Grille
Engine light on
How cant i tell whitch is cylinder # 7 on 2004 f-150 4.6 v-8
  • Ford Master
  • 2,210 Answers
Usually, but not always, the number 1 on a v8 is the front right cylinder as looked at from the hood. Therefore cyl 7 is the rear right hand. As in the odd number bank, 1 3 5 7
Posted on Jul 30, 2014
Speedo,all dash lights not working on peugeot 307 05 reg, all I done was go to test for a live wire,then these things not work,but car still starts & drive
you might have blown the panel cluster relay located in engine compartment.,on located in or around the fuse panel.
most relays that are the same size can interchange with one another, try to find the bad relay.
Sep 21, 2014 | Cars & Trucks
Vehicle missing,shaking,engine light comes on
Misfire could be a number of things:
a) spark plugs - change them if used over 15K miles - inspect/regap.
b) spark plug wires - change them if over 15K miles - inspect
c) ECM (electronic control module) - test with HEI (high energy ignition) tester.
The shaking tells me that the engine is running on less than its normal compliment of cylinders - the shaking is produced by the imbalance caused in the engine by one (or more) cylinder(s)
not firing at all.
The "Check Engine" light probably is coming on due the the misfire condition. Go to Pep Boys or
Advance Auto Pats, where they'll tell you (free) your codes causing the "Check Engine' light to be
lit - the code coming from your truck's computer will probably be one or more of:
P0300 - Random/Multiple Cylinder misfire detected
P0301 - Cylinder 1 misfire detected
P0302 - Cylinder 2 misfire detected
P0303 - Cylinder 3 misfire detected
P0304 - Cylinder 4 misfire detected
P0305 - Cylinder 5 misfire detected
P0306 - Cylinder 6 misfire detected
P0307 - Cylinder 7 misfire detected
P0308 - Cylinder 8 misfire detected
P0313 - Misfire detected with low fuel
Jun 23, 2011 | 2004 Ford F150
I have a 98 ford expidition and the check engine light came on. i had it scanned and the code that came up is the temp sensor. i bought the sensor and cant find where it goes. can anyone help me and tell...
was it coolant temp sensor? Or the cylinder head temp sensor
also what engine size is in your expedition
Jay
also if you have P code (scanned engine code), let me know that also
Jun 06, 2011 | 1998 Ford Expedition
I have a 2007 Chrysler Sebring with a 2.4 engine. The check engine light came on and the car runs rough. Had the code checked and it came back with a 303, 302 and 300 codes. What is the most common...
Hello Frybird.
The codes you have are engine misfires.
Code 300 is random misfire (could be any cylinder).
Code 302 is cylinder #2 misfire and 303 cylinder 3 misfire.
Most common causes are ignition issues.
Spark plugs, ignition wires/boots and ignition coils.
Next would be fuel issues such as fuel injectors.
Next would be emission components such as EGR valves.
Then in a worst case condition would be engine wear parts (valves, camshafts etc.)
The place to begin is ignition as this is a common failure on most cars.
If you need further assistance regarding your question please ask me here in a comment.
Thank you for using FixYa.
KL
Feb 11, 2011 | Chrysler Sebring Cars & Trucks
1999 cadillac deville gives codes for a misfire in cylinder 1 and 3 but you cant tell when driving it except for check engine light is one. After driving for about 30 mins and shut off, there is little...
Replace your wires and plugs.The bit of smoke coming out is telling you that it is firing but only occasionally.First replace plugs because they are cheaper.
Feb 19, 2010 | 2002 Cadillac Deville
Display name / date time
1)First tell me mob-ph-whitch company.2)mob-ph-Model-no-otherwise donot solve.
Aug 25, 2009 | Lands Phones
I am looking for a larg 4 cyl. motor that is carberated whitch motor am i looking for
I think all 95 Maximas are equipped with V-6 Engines, none of them has a 4 cylinder engine in it. Why are u downgrading your power tran on this powerful sports sedan ?!
Jun 07, 2009 | 1995 Nissan Maxima
2004-2008 Ford F-150 Not For FX2 and Lariat Model Main Upper Aluminum Black AL Grille Logo
90 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
