Question about Viore PLC7V96 7-inch Portable LCD TV with Built-in Tuner - ATSC -
Viore battery replace
Replace battery
Where's the Manul for RC2011V TV for Viore TV for my tv?
The RC2011V remote came with several different Viore TV models, including the LCD22VH56. Manuals Lib has the manual for this TV here: https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html . The remote is described on page 10; the link to that page is https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html?page=11#manual . Additional information on using the remote with the built-in DVD player on this TV is in the DVD section. This starts on page 15, https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html?page=16#manual .
I hope this helps.
Nov 12, 2017 | Viore Televison & Video
Viore rc5006v remote not working
Check the remote control for its infrared emission. Check its battery contacts in the battery compartment for any rust or dust accumulated. Clean them well and check again. If it does not help you, remote control need cleaning. You have to open it to do this. If you wish to get more details about how to clean and repair a remote control, check this link. Details are there. Pull up older posts.
Mar 16, 2013 | Viore Used Original RC5006V Remote Control
I have a viore 42 in plasma tv and the picture is black and white how do i fix it?
Hello kdmuszik,
Welcome, and thank you for using FixYa!
Your issue is with your Tuner Board. This piece will have to be replaced. All commands for picture ratio, color, and size transmit to the TV through this board. I have inclusded a link to the board you should be looking for, below.
Tuner Board
http://www.ecrater.com/p/10863238/viore-tuner-board-311229714221j
Have a great day!
Sep 11, 2011 | Toymax Viore 42 in. Plasma TV
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
May 17, 2010 | Toymax Viore 42 in. Plasma TV
My viore 42 in plasma is not projecting image. I
The video IC module seems to be giving problems. Open the back cover and take a peep inside. Look for the module just short of the screen. replace it if need be.
Nov 07, 2009 | Toymax Viore 42 in. Plasma TV
Wow, viore sucks at making tv's and customer service
First,Most Manufactures only give a one year warranty on the parts and labor. You can look at the original Purchase Receipt for the tv for the Purchase Date. From that date you have a one year warranty. If you are past the one year then you are out of warranty and you pay for the cost of repair. Second You probably have a bad Power Supply and or a bad Main bd. Call the manfacture and ask for their Tech Support and go from there.
Jul 10, 2009 | Televison & Video
Cablevision remote won't work viore tv
I was able to program my viore tv by trying the code search:
1. Press the tv and sel buttons until the IO button turns red.
2. Press channel up or down until the tv turns off and the press the tv button to lock in the code.
Ps: Be pattient when searching for the code, it might take a while. HOPE THIS HELPS!!!!!!!!!!!!!!!!
Mar 09, 2009 | Toymax Viore 42 in. Plasma TV
Code for viore tv. 1403 does not work
Have you tried using Akai TV codes.
You could also contact Viore on 866 278 5900 or
Email Technical support. techsupport@viore.com
website www.viore.com
Jul 05, 2008 | Philips PM3S Remote Control
Viore PLC7V96 7-inch Portable LCD TV with Built-in Tuner - ATSC - Logo
15 people viewed this question
Top Viore Televison & Video Experts
Tom Chichester
Brandon Murphy
Lou Williams
Level 1 Expert
Are you a Viore Televison and Video Expert? Answer questions, earn points and help others
