Question about Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator
Freezer temperature is jumping to -9 and can't reset, how to fix it
What temp should freezer be set
One of the most basic ways to ensure food safety in your kitchen is to set your refrigerator and freezer to safe temperatures for food storage. According to the Food and **** Administration, your fridge should be set at or below 40 F (4 C). Your freezer should be set at 0 F (-18 C).9 Jan 2014
At what temperatures should your fridge and freezer be set? - Jsonline
archive.jsonline.com/.../at-what-temperatures-should-your-fridge-and-freezer-be-set-b99.
Nov 18, 2016 | Refrigerators
Over temp light on and refrigerator/freezer not staying cold.
Extended warranties usually are not worth the cost. My guess is that KitchenAid wants you to pay $73 out of pocket even though it should be absorbed as part of the warranty replacement of the refrigeration system.
Mar 08, 2017 | KitchenAid KBRC36FMS Bottom Freezer...
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
My 9 yr old Kenmore Elite fridge is warming up!! The freezer is fine!!!! Model 3 106*74902401 Seriel # ES423704 Manufacture date is 10/2005, I purchased it in Dec of '05 and it's been WONDERFUL!!
This problem sounds like a damper control broken or frozen.
Lowering the freezer temperature may help to fix the problem as the damper sometimes freezes and not able to open to cool down the fridge side.
If lowering the freezer temperature doesn't help, you may need to call for a technician to fix or replace the damper control.
Also, be sure the door closes properly and no air comes in or out from the fridge.
Dec 18, 2009 | Computers & Internet
Freezer and refrigerator side temperature is automatically set at 62, when I reset it, it automatically jumps back to 62, what could be the problem???
Unplug the unit for about ten minutes then plug it back in and try resetting it. If that doesn't work you'll have to call in a tech. Solid state units have to have a professional there to fix.
Jul 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Samsung model rs2533sw control panel not coming on
http://www.fixya.com/support/t1914675-control_panel_not_working_samsung
Nov 30, 2017 | Refrigerators
Freezer due to brown out then power restored now low temp alarm
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
Feb 14, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator Logo
21 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
