Question about Brother IntelliFAX 2800 Laser Fax
Cleaned the drum by running the slider on Brother IntelliFax 2800
Before I cleaned the drum the copies were basically fine with a couple of spots on the page here and there. Now the copies are black and smudgy along more than one half of the page. A lot of loose powder came out of the drum when I removed the cartridge.
  • Brother Master
  • 1,684 Answers
The developer drum has a electrostatic coating material that holds the toner until the paper that is opposite charge pulls the toner off. If you wiped the drum unit to clean it, chances are that you damaged this electrostatic coating and killed the drum. You should never touch the drum surface or wipe it off because of this coating. At this point the only thing to do is buy a replacement drum.
Buddy
Corporate Computer
Over 21years of PC and printer support/repair
Posted on Jun 19, 2009
  • 1,959 Answers
Clean the corona wire, reclean the drum, check the toner cartridge. The cartridge may not be positioned properly, causing extra toner to be displaced.
Print out of faxed copies are too dark AFTER the first 3
You need a new drum unit. The built-in cleaning blade has worn out.
Apr 11, 2010 | Brother IntelliFAX 2800 Laser Fax
Horizontal lines and tones specks around text
Only known causes are a dirty corona wire or a dirty/bad drum. If you know the drum is good, a thorough cleaning of the drum and cleaning the corona wire should clear up your printing.
Jun 19, 2009 | Brother IntelliFAX 4100 Laser Fax
There is a line coming through when we receive faxes.
Try removing drum unit, and cleaning corona wire with blue "slider" if that doesn't work, replace drum unit.
Apr 29, 2009 | Office Equipment & Supplies
Copies arent good
clean the printhead above the drum and you should be fine
Mar 17, 2009 | Brother Office Equipment & Supplies
The copies print with 2 white streaks where print should be
pull the toner/drum unit out of the machine. on the top of the drum unit there is ether a blue or green slide lever. move the slide back and fourth 10-15 times. if you have canned air blow out the area where the slide is. reinstall the drum unit see if this works
Good Luck
Jan 29, 2009 | Brother IntelliFAX 2800 Laser Fax
Light image on one side
You need to replace the drum (DR-250). The drum needs to be replaced every so often. Sorry, it's kind of expensive. If this helps you, please give me a good rating. Thanks.
Aug 19, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Incoming fax quality
Are you using genuine Brother supplies? Generic supplies are the main reason for print quality issues. Have you ever changed thr drum unit ? Expensive! You can buy a new machine and get a new drum and toner for a little bit more.
Oct 22, 2006 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
298 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
