Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Fridge not cooling
Freezer is fine, bottom of fridge seems semi-cool, top is not at all
  • 8 more comments
  • bigdog972 Jun 21, 2009
    Yes it is. I just unplugged the freezer th other day, pulled the racks out of the freezer side, and unbolted the back panel on the inside. The coils were covered solid with ice - is that normal?. I let it defrost for a day, plugged it back in, and all is well.... BUT, I am pretty sure that your suggestion is right, and that nothing is stopping the ice from accumulating. I am assuming that the fan also got frozen, which is why the air stopped circulating... I will leave that diagnosis to guys who really know their stuff.. like you :) Please advise, thanks for your help....
    No, it is no longer under warranty, can I run to sears and pickup a standard multimeter, or do I need a specific kind? Thanks.
    No signs of burn on the board, gotta run to sears to grab a multimeter, so I'll write you back when I get it.. Thanks again for your help.... talk to you soon
  • bigdog972 Jun 22, 2009
    I emailed you earlier, and you did send me the manual. Thanks a ton for that. Last night I noticed a sound coming from the icebox. I left the control panel off while messing with the defrost board. I put the board back in yesterday after chatting with you until I could get a multimemter. When I opened the icebox, there was a loud tapping sound coming from the defrost board. Is it safe to assume that the Adaptive defrost board is bad since it was making such a big noise? I am thinking to just order the part if I can't find it locally today... let me know what you think.....
    Thanks sea breeze. I'll run to sears on my lunch instead of the appliance store. I'll write you back after I attempt to run the tests. Thanks again for your insight. I am a computer guy, and can totally relate on making sure that all things are checked before putting everything back together again.... talk to you soon.
    sea breeze,
    Just got this multimeter from sears @ 50% off
    http://www.craftsman.com/shc/s/p_10155_1...
    Soon as I figure out how to use it (I have never used one before), I'll get those parts tested and get back to you, any other tips to make sure I don't blow my self up? Thanks.
  • bigdog972 Jun 23, 2009
    Ok, need some help with the testing of the thermostat and defrost heater. I have enclosed a picture, where do I put the red probe, and where do I put the black probe? Not too clear on the whole 22ga jumper test either... says to unplug and hookup to a wattmeter? Thanks again for everything.
    I pulled the 3 wire plug... 2 white wires from the heater, and one thick black (ground I assume). I tested across all combinations, and I have readings on all of them (wht1-wht2, wht1-blk, wht2-blk) hopefully that is good news.....
  • bigdog972 Jun 26, 2009
    You are the man sea breeze. Thanks for all your help! Left it running a couple days to make sure, and all looks good.... except - for some reason the ice maker isn't making ice anymore? could I have unplugged something by accident? If not, no worries, I'll dig around on the boards...
  • Jenn-Air Master
  • 4,655 Answers
We will need to see if yours has the defrost timer or the adaptive defrost. Let me know if your model is the JSD2789GES. I have the manual we can work with. ..Sea Breeze
Posted on Jun 21, 2009
  • 7 more comments
  • John Tripp
    John Tripp Jun 21, 2009
    No it is not normal. I just would like you to have a multimeter or ohm meter First is the refrigerator still under warranty?Your refrigerator has an Adaptive Defrost Board inside the fresh food compartment and behind the control panel. The part number is 61005988 it is most likely the reason for your trouble. It may be defective. Providing the model is the model above your post which you said yes it is? OK that out of the way I need you to unplug refrigerator and lets get a meter and tackle this thing. I need you to have a look at the Adaptive Defrost Board and test the defrost heater by removing one wire on one end and see if there is continuity. Your part is listed in a photo of the part is in top right corner of this page===> if you need just click on photo
    http://servicepartstec.blogspot.com/
    Look for a sign of heat or burn marks on the board. If none lets move over to freezer and check the element or defrost heater. Let me know what you find. Sea Breeze
  • John Tripp
    Any meter will be fine, the continuity through the defrost heater is about the only thing I will need you to check. The defrost thermostat is attached to one end of the heater and acts as a shut off for the defrost heater when the temp rise above 50 degrees. They go bad too but above 50 degrees you won't get a reading because the contacts inside are open. If bad it will not allow defrost. I did read somewhere that it would show some reading open. Anyway don't worry too much about that. We need to focus on the Adaptive Defrost and then move over to freezer. But if you need to replace an heater you need to change it also. The fan may have stopped because there was no where for the air top go, I hope that is why.
  • John Tripp
    John Tripp Jun 22, 2009
    Email me when you get back so I can send you the service manual. It will make some of this easier for you to follow through with me. Its about 118 pages in PDF format.
    appliancepartsse@yahoo.com
  • John Tripp
    I would not say its safe to make a dicission by the sound of the Adaptive Defrost Board. When you unplug the defrost heater you should get a good reading for continuity. The defrost thermostat should show 20 to 40 ohms. The odds are you need to replace the Adaptive Defrost or both defrost heater with thermostat included. In the maual it tells you can unplug refrigerator and with a #22 guage wire place a jumper from L1 to test. If you manually put the defrost heater in defrost the it will get hot if working. Go to page 43 in the PDF I would say the odds are the ADC but if you have not checked the defrost heater I could be wrong and you need to replace the defrost heater and defrost thermostat. That comes together as a kit.
    Sea Breeze
  • John Tripp
    Just don't set it on ohms and touch the probes to voltage. I'll be here. Sea Breeze
  • John Tripp
    John Tripp Jun 23, 2009
    Go to page 45 in the PDF I sent you. There you see 2 wires coming out of the defrost heater. Unplug the pin plug and check across those two wires. If you get nothing for reading then skin a small place on the wire coming between the defrost thermostat and the defrost heater and test it there. On ohm's it does not mater red or black. Set your ohm meter so that if you hold one probe in one hand and the other hand you get a reading. If you squeeze harder you get a better reading. That is mesuring the continuity between both hands and through your body.
  • John Tripp
    What type reading like there was no resistance or 20 to 40 ohm's through the defrost thermostat. In the manual I saw the defrost thermostat has a resistor built in so if the temps in freezer are above 50 degrees you should get the 20 to 40 ohm's through the defrost thermostat. Freezing you should get the same reading you get just like touching both probes together. If you skin the white wire between the thermostat and the heater and touch the black wire on the black wire side and the skinned place on the white wire you should get the same as touching the probes together.But I think now the problem is in the ADC
  • John Tripp
    John Tripp Jun 26, 2009
    Don't leave without rating me. We'll get the ice maker. So the ARC? Se Breeze
  • John Tripp
    I'm little confused my site seems not to be working properly.
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Amana Refrigerators
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
466 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
