Dirty steaks on clothes at end of wash cycle.
We have a Bosch Maxx WFL 2450. There appears to be a build up of grime/gunk perhaps in the drum. When the cycle finishes the clothes touching the drum are covered in brown streaks, also flecks of some residue/grime. It appears to be seeping out of the holes into the space where the clothes go. And now there is also a terrible smell! We have cleaned out filter at bottom but nothing much there. Descaled a couple months ago as well. Not sure how to ''clean'' it up or what to use or whether it needs a service. it is 8 years old. Any ideas of what might be the problem and how we fix it? We use the machine a lot, once every other day at least. All suggestions welcome! Thanks.
  • paperasse Jun 19, 2009
    Thanks for your comments. I tend to use an ecological liquid and run the wash at lower temperatures (as we are told this is more environmentally friendly!). Will run a few hot washes as recommended and try a different powder and see how we get on. Many thanks!
    President:
  • 1,185 Answers
Make up a couple of liters of a strong solution of hot water and Soda Crystals, pour that mix into the machine without any laundry in it and do couple of very hot washes
Change your soap powder to one of the old fashioned ones for a month or so and see how you get on.
Cold washing tends to leave body fats and other greases inside the machinea s there is little to break them down in "Modern" powders
Posted on Jun 19, 2009
  • Tom
    Tom Jun 20, 2009
    Using the hot soda mix is the main step to take to get rid of the current build up
  • 867 Answers
Is the transmision leaking oil?
How to remove *** wire from bosch wfl 2450?
Here you go....
http://www.scribd.com/doc/187416757/Bosch-Maxx-Wfl-2450
Aug 21, 2014 | Bosch Washing Machines
Bosch maxx wfl 2450 does not drain and does not go into spin cycle
Had the same problem with my Bosch SHX45P05UC/64 Dishwasher. Tried all the solutions - cleaning the bottom, forcing the "flapper", draining manually etc - found on the net, including on YouTube. No dice.
Finally called Sears Service. He walked in, didn't even bother with the dishwasher. Popped open the "vacuum release" (my name for this ;) on the top of the sink (next to the faucet), removed the gunk that had accumulated it, closed the top again, and turned on the dishwasher. Presto! Worked like a charm. He was in and out in less than a minute. Very cool! Try it out before you do anything else. :)
May 03, 2014 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch Maxx WFL 2450 Washing machine Electric fault
hi there ...it sounds as the watyer leak has found its way into the motor windings and damaged the motor..and the control module.....could be a very expensive repair
regards Sir Galahad
Aug 18, 2009 | Washing Machines
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
364 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
