Question about Bissell PurePro Multi Cyclonic Bagless Upright Vacuum
My bissell will not pick up trash
I think I cleaned all the filters but my vacuum will not pick up trash
SOURCE: My Bissel 3750E vacuum won't pick up.
also, check the connection between the main unit and the brush base, If it is burnt, then ou need to contact bissell for a replacement.
Posted on May 27, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
  • 231 Answers
SOURCE: Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Posted on Jan 07, 2010
heatman101
  • 43501 Answers
SOURCE: 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum: My Bissell ProHeat 2X will not pick up the water a...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gh
Posted on Sep 30, 2010
  • 53 Answers
SOURCE: Model #3760-2 Bissell upright vacuum-
Is the noise coming from the belt area, ie. beater bar, or does it sound like it is coming from the motor itself? It is possible there is something caught in the brush roller.
When you turn the roller off, does the noise go away?
Posted on Dec 20, 2010
How to fix my Bissell vacuum it sounds like a really loud airplane about to take off its isn't that old .
It has a two year warranty so just return it. Sounds like a motor fault unless you have something caught in the drive belt or the brush roller. Tip it over and remove the base plate.
PowerForce® Helix™ Bagless Upright Vacuum' BISSELL®
https://www.bissell.com/powerforce-helix-bagless-upright-vacuum-1700Main Information. Product Title: Powerforce® Helix Bagless Upright Vacuum ' 1700. Model: 1700. Similar Models: 17003, 17004, 1700R, 1700U, 1700V. Quantity: 1. Warranty: 2 year limited. Register. Register Your BISSELL® Product ... Bissell 17003 Google Search
Mar 27, 2018 | Bissell Vacuums
Bissell carpet cleaner does not suction
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 17, 2012 | Bissell 1699 ProHeat Clear View Upright...
My bissell vacuum has no suction. the power works and the brush turns but I have no suction. what should I do?
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Ava B.
Sep 25, 2010 | Vacuums
I have a ProHeat Bissell 8910 Series. Won't release or pick up
heatman101
yoi
Mar 20, 2010 | Bissell 8910 ProHeat Clear View Upright...
Not picking up dirt
clean ALL the filters or buy new one it would be better to buy all new filters also check for clogs in the vacuum also check the belt if the belt is broken it will not pick up much 1. check all tubes for clogs if still dose not pick up 2.check the belt and replace if broken if it still dose not pick up 3.do the filters that worked on my bissell
Feb 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissell LOUD noise!
To fix any noise issues that your Bissell vacuum gives, a proper maintenance will do the trick. Most of the time, cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. You may need to refer to your User's Manual for instructions on proper cleaning and maintenance.
Ava B.
Feb 01, 2010 | Bissell Vacuums
Not picking up cleaned all of filters is there a belt for this
It might be because the belt is broken, stretched or worn. In all of these cases the vacuum won't pick up well. You can get the replacement belts for this model and download the manual which has instructions on how to change the belt here:
Bissell Lift-Off 37604 Replacement Belts and Manual
Nov 05, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Hello, I have the same model. And though it is three years old, starting from the last month, it does not clean anything anymore. Cannot even pick up one single thing from the floor. Every dirt gets stuck...
i know bissell vacuums are very cheap but they should last more than 3 years. there should be two parts to the dirt cup. remove the dirt cup and above it there should be a round plastic part. unscrew it and check that filter.
Apr 06, 2009 | Bissell 6594 PowerForce Bagless Upright...
Hose not picking up
Hi MightyHeidi,
About once every 9 months to a year, I have to take the hole Cleanview apart and thoroughly clean filters and get all the trash and string from the roller Brush.  I was the cleanview buckets out and rinse the filters untill i get no more mud flowing.  ThenI let it dry for a day or two. Put it all back together.  About once every 3 years, you may want to do a full disassembly to get to the Check valve at the intake of the Blower Motor.  i found mine stuck open and causing me to loose vacuum.
Sep 01, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 2x steam cleaner
Usually when it won't pick up water is because the bucket isn't seating all of the way down. Or there is a window gasket or seal, it goes bertween the clear window and the bucket, if it is missing, yiu get no suction thru that clear window. The other is on the one side of the lid for the bucket is a filter, is it clean? And the seal that that filter sits on, is it sealing? If the moror is running, it is sucking, but any leak will cause it to loose that suction.
Aug 30, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell PurePro Multi Cyclonic Bagless Upright Vacuum Logo
13 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
