Question about T-Mobile Sidekick® 3 Cellular Phone
The screen wont come on my sidekick 3...ball still works
When i opened my sidekick the screen was upside down i closed it still upside down...so i turned off turned back on now it only show up a white screen...any help?
    President:
  • 625 Answers
Yeah, more than likely the lcd cable connection is loose. That is what the white screen usually indicates.
It is fairly easy to take a apart and reseat.
Follow the guide at the link below
Fix Sidekick 3, Sidekick ID, Sidekick II White LCD Screen
Posted on Oct 06, 2009
The screen on my T-mobile Sidekick 3 went white.
You need to reseat the LCD cable. More than likely it has come loose in the back of the LCD
Follow the guide at the following link.
Sidekick White Screen Repair Guide
Jun 14, 2010 | T-Mobile Sidekick® 3 Cellular Phone
It just turned black n wont turn back on i dont
which sidekick is it? i have the samee exact issue my green ball still works but the back light for some reason doesnt work i have the 2008 one
Jun 13, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My screen on my sidekick slide wont slide smoothly
ur bolts are loose u will need to get it fix and u will need to not flip it alot that is wat causes it
Apr 29, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 keeps locking up
Go to setting then go to system info....then press
Menu +shift+x
Then it will ask something...and press yes
Feb 02, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Help me please!!
Take you unit to a T-Mobile store and find out what your options are.
If you have insurance coverage (and you should with that phone), it can be replaced with a deductible.
I have a feeling it has to do with a short in the screen cable.
Does it make difference in the display if the keyboard is opened or not?
Oct 19, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My new 2008 side kick is not working
If your holding your phone upside down with the track ball to the right, slide the back cover to the right.... It should slide right off....
Oct 11, 2008 | T-Mobile Sidekick® 3 Cellular Phone
PLZ HELP SIDEKICK 3 SCREEN WENT RED AN GREEN
reylakers-
You can try and reset the flex cable on the lcd.
follow these instructions.
Fix Sidekick White LCD Screen
If that doesnt work then a new lcd screen unit will.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 wont stay shut.
prod7-
Flip the LCD screen open, look on the backside of lcd assy, in the top center is where the magnet goes. You will need to take the front lcd cover off to put it back on.
Sidekick 3 LCD Cover Screen Replacement
May 03, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 problems
Antonio-
You may be able to fix many of those things yourself. The trackball proabaly just needs to be clean. Does the LCD have a white screen when it is on? The Camera, well that may take some work.
For the white screen check out here: http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
If it is not white, a new lcd can be had for 45 dollars on ebay.
they are easy to replace.
replacement of the Sidekick 3 LCD flip screen.
To clean your track ball, follow these instructions:
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Apr 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-mobile sk3
HI im a tech at repairmysidekick.com the problem is the white screen is because of the many times you fliped the screen open or close and the flex cable which connect the screen to the phone is damaged...if you like an easy fix you can try to open the screen halfway and stick a paperclip in the pinhole on the right to soft reset the lcd if it doesnt work you can also try to remove the screws on the crome base and turn the screen upside down...check the leeds if they are gold there good if black you need to change the flex cable we can do it for you. just visit repairmysidekick.com
Dec 19, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
159 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
