Question about Microwave Ovens
Kenmore elite 721 79202010
When hit start...it says power ....
How do I turn off the sound on my new Kenmore Elite microwave?
I Believe this model has an options button with codes by numbers which are 1 thru 6 I believe. Either 1 or 2 are sound. So hit the options button and hit the number 1 it should say (sound), Then you will hit 1 again a.k.a. mute, and no more beep beep beep. If 1 is not sound then you may have accidently created a small but deadly emp, so hit stop and you must hit options and then hit 2.
Dec 11, 2014 | Kenmore EM262A5E Elite Stainless Steel...
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
What does F-7 error code on Kenmore Elite microwave mean
That's a problem with the inverter or another high voltage part.
Dec 24, 2012 | Kenmore Elite Over The Range Microhood...
Kenmore Elite Microwave has power but will not start?
switch if off completelty for approx 5 mins and then power it back on
Oct 26, 2011 | Microwave Ovens
Hi, i own a kenmore elite speedcook oven model 363.63692301, ever since my wife used the convection speedcook oven and had the heat setting set to the maximum temp of 450 degrees which the oven should...
I have had issues with my Kenmore Elite conv oven too. I have had several service calls and found out that the TCU (thermal cooling unit) sensor was not working. This allows the oven to cool down so it doesnt overheat the sensors in the display. I actually had to have the oven replaced after 4 months of use. I am currently waiting for a technician to review the replacement oven for the same issue. I spent $7k on all new Elite appliances and will never purchase Kenmore appliances again. Good luck
Nov 30, 2010 | Kenmore Microwave Ovens
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
Kenmore Elite taking long time to heat items
This is most likely a failing magnetron.
If it's less than 5 years old, Sears/Kenmore should cover the part, but you would still have to pay for a service call.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 16, 2008 | Microwave Ovens
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
