Question about Dometic Rooftop RV Air Conditioner
Ac goes off when hot water is being used ac throws braker when you use hot water
  • 4 Answers
Is your hot water heater electric maybe there is not enough amps to drive both at the same time
Posted on Jun 20, 2009
  • 867 Answers
This is amazing. these 2 things have nothing to do with each other. the only logical explaination would be the hot water leaking on the supply lines to the a/c, causing a short
Posted on Jun 19, 2009
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
Elec water heater 40gal water way to hot and blowing braker on the water tank Red reset button what wrong please help
One of the thermostats is bad or there is corrosion behind it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Feb 14, 2011 | Water Heaters
How to operate Rinnai V1500 water heater?
The V1500 is in essence the same as Infinity 26. Rinnai have manuals on their website.
Here's a link
http://www.rinnai.com.au/images/stories/operating_instructions/Hot_Water/All_Continuous_Flow.pdf
If you have any specific problems or queries just post them on this site. I check it every few days.
Cheers
Aug 15, 2010 | Water Heaters
Engine temp goes hot when A/C is running. A/C
Possible loose AC belt but more likely a water pump issue. Putting the AC on puts more strain on the water pump to circulate coolant which also would impact the AC performance.
Aug 02, 2009 | 2001 Jeep Grand Cherokee
Replacing a 40 gallon electric hot water tank with a 60 gallon hot water tank
Check what the "AMPERAGE" (Amps) is stamped on the info tag on your present heater --- If the number is the same or lower you shold be able to use the same wiring -- If the amperage is lower all you'll to do is lower the amp size of the fuse / braker
Apr 24, 2008 | Refrigerators
Problem with my dryer
unlikely a fault with dryer. try plugging another high consumption item into the socket you use for the dryer ie elec kettle or iron. see if breaker still trips and if so you have fault in socket or house wiring. if you put a plug on the dryer yourself, check you have wired plug correctly
Mar 24, 2007 | Whirlpool LER2614JQ Electric Dryer
No voltage/current to hot water solinoid.
do you have power at the SWITCH-TEMPERATURE check to see if you may have pull off a wire or shorted it..let me know
Nov 03, 2006 | Frigidaire GLWS1233A Top Load Washer
Dometic Rooftop RV Air Conditioner Logo
66 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
