I have nissan micra k12 53 plate when you turn the key all the lights are on ready to start but when you turn the key nothing happens. I have changed the starter motor put start button instead of changing the ignition barrel but still nothing happening any idea what can it be please. Has a new battery as well thank you
Hi there.
this youtube video might help you out.
NISSAN MICAR k12 WON START OR TURN OVER RANDOM PROBLEMS WITH IGNITION
or this google link.
Nissan micra k12 won start Google Search
SOURCE: Turn key to start - nothing happens
I had same problem w/ my '88 Ram50. Turned out to be bad contacts on the battery cables. Temp fix and test was to put a little screw between the post and the end connector. Didn't have a problem then, so I replaced the cables.
SOURCE: motor does not start when i turn on ignition
did u have the alternator tested to see output get a jump if the car starts takeit to a auto zone have him test the battery and alternator for free
SOURCE: starter enabler fuse blows which means the starter motor does not work until fuse is changed
It is possible that the starer is pulling too much amperage- 1st thing you need to do is find out what if any other consumers are on that circuit, 2nd you need to find out how much amperage is being consumed by the starter. 3rd test you wires most likely if a wire problem it is the heavy hot wire on the starter or the back of the alternator has a loose retaining nut
SOURCE: changed starter...new battery....lights and radio
Starter Fuse? Possible failed ignition switch. Loose Cables on battery or starter. Starter not grounding properly. Bad starter Relay? Use Voltmeter check voltage going to main starter wire while someone cranks the motor if not power check power to starter relay while cranking if no power suspect ignition switch.
Check the neutral safety switch on the transmission. It should have three wires on the connector (if I remember correctly). There should be power on the Brown with yellow wire with the key in the crank position. If there is ground that wire and see if the van starts. If it does replace the switch. If it does not check the starter relay.
Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
