Question about Vehicle Parts & Accessories
Repair warning light
Transmission lite
The spot for brakes on the dashboard has an IP lite up on it. what does that mean?
CHECK OR HAVE SOMEONE CHECK BRAKE FLUID LEVEL, BE SURE PARKING BRAKE IS NOT ON!
Jan 22, 2016 | Cars & Trucks
My BMW 318i 2003 automatic transmission not responding to gear liver. what is wrong with my car?
the transmission warning light is an indication of a fault in the transmission which you apparently ignored. You were supposed to have that fault codes read immediately the light came on as that is when the repair will be at the cheapest. have the codes read now to determine what is wrong
Nov 12, 2014 | BMW 318 Cars & Trucks
Exterior warning lite stays on
The corning light only works when the turn signal is on is normal.
What are you talking about with an exterior warning light ? The light on the dash that tells you one of the exterior lamps is not working ?
Aug 19, 2012 | 2000 Ford Windstar
2001 3 Series: automatic warning lamp came on on my 320ci...
Which warning light? Check engine? Traction? Transmission? Can you give me a more detailed description? With a check engine light Autozone will check it for free and give you the code that caused the light to come on. With the code you can troubleshoot and repair.
May 17, 2010 | 2001 BMW 3 Series
Warning light of an engine on audi a6 has lite up
tghis is the check engine light, this means u have a problem in the electroincs that control the engine or the emission system, this is outlined in the owners manual.
Apr 26, 2010 | 2000 Audi A6
Don't know what warning light means
What exactly does the warning light look like? It is probably the transmission warning light. The transmission uses the radiator to cool the transmission fluid. You need to have your cooling system serviced on a 10 year old car. Drain, flush, fresh coolant, new thermostat. A full service. Keep driving and you may end up with a transmission repair. Good luck.
Nov 17, 2009 | 1999 Saturn SL
Where is the transmission dip stick? 2001 Jaguar XJ8
Alot of the new cars are eliminating the Tranny dipstick and replacing it with a warning lite on the dash... Personally I'm disappointed because I would rather have a little more forewarning...
Check your owner's manual for the indicator light info.
K
Sep 25, 2009 | 2001 Jaguar XJ8
Ignition key stuck
your key is stuck because of the transmission problem
Apr 07, 2009 | 2000 Pontiac Montana
Eac fail lite up on dash and engine light lite too.
My car has been doing this for a few months, paid £80 to get accelerator pedal changed, this didnt help, EAC fail back few days later, am now having throttle body changed and have just found out that on board computer is US, so its going to cost me £1100 !!!!! Deep joy.......
Jan 10, 2009 | 2004 Ford Fusion
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
