Question about Lowrance Elite-7 HDI Chartplotter/Fishfinder - 000-10970-001
Down imaging doesn't work - Lowrance Elite-7 HDI Chartplotter/Fishfinder - 000-10970-001
Wont turn on
If you can get into the bootloader try doing a factory reset, if you are rooted press and hold the power and vol down button and that would boot into recovery. Worse case, you can google factory images for nexus 7 e and download a factory image from google and they provide the instructions on how to reimage your devices
Apr 17, 2013 | Google Nexus 7
N73 nokia, i have problem in take of the image capturing , in the image capturing mode doesn't key accept for image capture but it has work for video capturing. so plz help me what i do?
Generally the image capturing button should press 1-3 secs to get a picture.If it doesn't works there might be some hardware problem.But first try to Restore the phone by typing *#7780# and capture.If the problem still persist contact mobile repairing shop. The camera switch may damage .Or at least clean the pcb if you can remove the cover ..Thanks for visiting fixya
Mar 18, 2012 | Nokia N73 Cellular Phone
My in built camera for acer aspire one KAV 10 doesn't work anymore
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver hope this helps
Jul 28, 2011 | Computers & Internet
How i can resize my photo?
  1. Click "Main Menu" and then "Edit."
  2. Select "Image Size" from the drop-down menu. The Image Size dialog box will open.
  3. Check the "Keep Aspect Ratio" box. This keeps the image proportional and doesn't distort the photo.
  4. Enter a new value for the size of the image in the width or height box. Then click "OK" to resize photo.
HOPE THIS HELPS...
Jul 01, 2011 | Arcsoft ShowBiz DVD 2 (3265)
My SerifDrawPlus X3 reboots unexpectedly after I apply image effects to an image...reads "program closing windows 7 is trying to find solution to this problem" - can you help?
This could mean your PC overheated, had a error or another problem causing Windows to force it to shut down. Is the fan in your PC working right? If it isn't working (correctly), buy a new one. If you don't know how, here's a good guide how to. If it is working correctly, a error might caused it. If so, Windows 7 will find a solution for it. Check the white flag next to the internet and volume icons. If these to are not the case, your PC might doesn't have enough memory to hold image effects and too less RAM (Memory) could cause a unexpected shutdown. Don't hesitate to ask me more! Thanks for using FixYa, and have a great day.
Jun 04, 2011 | Computers & Internet
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
My 17.0 R image incline stuck in the highest mode, how do I bring it down.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 14, 2010 | Icon Image 17.5 S Treadmill
Quit working blinking light above settings knob
These things may not SEEM to move air, but they do - slowly and steadily purifying the air and adding a negative ion charge to the air which helps the dirt in the air fall down and be captured during vacuum cleaning, sweeping, etc.
Aug 08, 2009 | Sharper Image Professional Plus Ionic...
Sony DSR-PD170 Color Problem
sounds like a problem with the image sensor, or an intermittent cable connection to the sensor.
Jan 06, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Lowrance Elite-7 HDI Chartplotter/Fishfinder - 000-10970-001 Logo
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
