Question about Sony SA-WM40 Subwoofer
SA-WM40 no electrical power/ won't turn on
When I plug it in it doesn't turn on. one day I was messing wit my neighbors and all of a sudden it just quit on me.. depressing.. ha and i'm not one of those heads that jus turn everything thing all the way up sounding like **** and worndering why its not working either aha. its my baby
3 Suggested Answers
  • 308 Answers
SOURCE: The speaker is starting to buzz during the low
It probably buzzes all the time, you just notice it when it is outputting little volume. Check the cables for loose connections or replace them with other cable as a test.
Posted on Mar 12, 2010
dunnbiker
  • 8546 Answers
SOURCE: My Sony SA-WM40 subwoofer has
Probably, or the woofer coil itself is experiencing a heat, volume or motion related short. Clean any dust or debris from the heat sink fins in the back. Make sure it has lots of space for cooling ventilation.
Posted on Mar 31, 2011
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
My Panasonic SA-PT875 surround sound system won't
Hi, I have the same issue ! ... Can you let me know if you fixed it please.
Regards Brad
Aug 16, 2011 | Panasonic Audio Players & Recorders
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
My Sony SA-WM40 subwoofer has power, but sound kicks out. I'll turn off power for about 5min and when turn power on, sound is back. Is something overheating?
Mar 31, 2011 | Sony SA-WM40 Subwoofer
My sa-ma40kicks off after it plays for a few minutes
This sounds like a power supply problem. If it works after is sits or cools, check at the power supply for bad or disturbed solder connections, a lot of time if you look at the circuit board where the component comes through you will see a small ring in the middle of the solder.
Dec 22, 2010 | Sony SA-WM40 Subwoofer
Mar 08, 2010 | Sony SA-WM40 Subwoofer
I don't have no power replaced the fuse still no power
i have a sony subwoofer with no power. i found out that the voltage regulator (ic's)are bad. check that.
Dec 07, 2008 | Sony SA-WM40 Subwoofer
My sandisk mp3 512 player won´t start
i really dnt kno this happened to me too im tryin to fix it the best thing u can do is call em up on sandisk.com IF u havnt already tried to mess wit it already if u do find out how to fiix it, PLEASE email me at tsingh66@sbcglobal.net
Mar 19, 2007 | SanDisk Sansa m230 MP3 Player
Overload on Technics SA-AX710 Receiver
first of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Nov 22, 2005 | Technics SA-AX710
Sony SA-WM40 Subwoofer Logo
75 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
