Question about Behringer HPS3000 Studio Headphones
Behringer hps3000 headphones right speaker doesnt work
How do i take it apart?
2 Suggested Answers
knight_nemes
  • 11 Answers
SOURCE: No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
Posted on May 04, 2012
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
How to connect Behringer qx1200 mixer with pc and pc/speaker? I tried all solutions but i didnt' get any sound. Earphones works great
the mixer connects to the pc via usb or analogue i/p's
the mixer does not connect to the pc speaker
this has to be done with the software you're running on your computer
the easiest way is..plug the headphone o/p into any amplifier line i/p
( amp and speakers or powered monitors ) and forget about the pc speaker ..they're sh!te period ..or you can plug the headphone
o/p into the mixer then the mixer into an amp but this is more complicated and you will need to read up on it
but do yourself a favour and get some small multimedia speakers
similar to these for starters http://www.ebay.co.uk/itm/GENIUS-BLACK-MULTIMEDIA-STEREO-SPEAKERS-SYSTEM-for-LAPTOP-DESKTOP-PC-COMPUTER-UK-/250929417549?pt=UK_Computing_Speakers&hash=item3a6c8f0d4d
May 28, 2014 | Behringer Audio Players & Recorders
I turn on the amp (Behringer Ultrabass BHX1800) and there is a large popping sound but then I have no sound output from either the jack inputs or the composite stereo inputs! before I take it apart, does...
I suggest you look for a new amp. My husband has had these apart and parts are almost impossible to find. One part took over 6 months to get.
That said you can look at the Jacks... they break a lot.
Jul 27, 2012 | Behringer Ultrabass Bx1800 Bass Amp W/...
Blown speakers?
usually with a blown speaker you will get sound but it sounds like there is an abundance of paper very loose on the speaker, so if there is no sound at all try taking the box apart if you are familiar with stuff like this and check to see if there are any loose wires or blown capacitors
Jun 24, 2012 | Behringer Music
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
May 04, 2012 | Behringer Ultrabass Bxl3000
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
Can you connect single behringer powered speaker to dell desktop
if you are good at wiring you could take old headphones and use it and plug it into the headphones jack and have it work without frying it but if you arent good at wiring dont atempt to because it could hurt the powered speakers or the computer
Mar 14, 2010 | Behringer Eurolive B212A Speaker
No sound from headphone
Worse case scenario is that your left speaker is gone but usually what happens is a break in the cable someplace.Are you using the 1/8" plug or are you using them with the 1/4" adapter. The 1/4" adapter might be worn out but is easily purchased and replaced.The cabling from the plug runs into the left can and from there splits into left and right speakers. There will be a wire that follows the head band under the cushion from left to right. With these headphones there is a swivel above the can and the problem might be in there. Half the problem is getting at the wiring to test it. Usually the plate that the speakers are mounted on is screwed to the back cup and the screws can be reached by removing the earpad. You will need a volt ohm meter to test the wiring. You can also test the speakers with it. Unfortunately most plugs on headphones are molded onto the cable so you will have to start by testing from the plug to the left can. Inside the left can will be a junction point where the main cable feeds the right speaker. Test up to there for right and left and if the connections are good then test the speaker. Hope this helps.
May 14, 2009 | Audio Players & Recorders
Broke one end of the cable that connects my 2 behringer ms20 speakers.Which replacement part do i need?
What input were you plugged into? If you are talking about the cable that connects the two cabinets from right speaker to left speaker, it looks like a standard RCA cable to me. It basically connects the signal content from the right cabinet to the left cabinet. It should be a shielded unbalanced RCA to RCA cable.
May 13, 2009 | Behringer MS20 Digital Monitor Stereo...
Behringer HPS3000 Studio Headphones Logo
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
