Question about Alcatel Cell Phones
Activate pin phone - Alcatel Cell Phones
Default password for samsung GT-E1080i
correct
there are two methods of providing security on a phone
the first is a PUK code ( personal user Key) that is set by the service provider and is activated after 3 false attempts of the sim card security or PIN number( personal identification number)
Now when you buy a new phone , you get a new sim card
that sim card will be programmed to include the details of the phone and the service provider and pin number
so if you loose the phone ( stolen) the finders cannot access your account as after 3 attempts of guessing you pin number the service provider makes the phone useless
the same as if you forget your pin number again the phone is rendered useless by the PUK code activation
So how do you get around all this
where you buy the phone , will have the ability to set it all up for you with a service provider , will provide you with an initial pin number and once you have activated the account they will show you how to enter a pin number of your choice and how to set it
so if you are having difficulties then take it back to the shop and have them show you how to do it all
Nov 26, 2015 | Samsung Cell Phones
Hi, please how can i retrive my phone pin code.
The pin code is on the simcard. The phone has blocking code, if you activated this option. Try to call your mobile operator to reset your pin code or to activate another new sim card with the same number.
Apr 04, 2011 | Samsung Cell Phones
How do I get a pin number for my h500 bluetooth?
the pin number is the code to activate the sim card to work with the phone!
pin and puk belong to sim card
the only codes requested by phone are "security code", "pin2" and unlock codes
dont forget to rate
Jun 17, 2010 | Cell Phones
Pin number bluetooth motorola h350. trying to activate this bluetooth to my phone but dont have the pin to it. Does any one know the pin number to this model h350? Thats all I need to activate it, I dont...
I hope it's the PassKey, Enter number you like and press ok, but when pairing with other device, you have to enter the same code to the other device. Good luck Thanks for using FixYa.
Jun 03, 2010 | Samsung Finesse SCHr810 Cell Phone
I lose my phone pin number. My mobile model is nokia 2700
Pin number comes with the connection. It should be on your subscribing papers of your provider. you may ask them to give it ti you or you may have to get another sim to get that pin back. Phone has option to activate or deactivate the sim's pin checking ... and as it comes with sim, your phone model cannot help.
Apr 23, 2010 | Nokia Classic 2700 Cell Phone
Dont Know My Pin 4 My New Sony Errcison G502?
pin generally is in your sim not in your phone.
if you put correcltly your sim pin and the phone request his own pin , well strange because new phones dont have activated the pin in request.
anyway look in your phone manual haw is the prefrabicated pin from the company. if you dont have the manual go to the sony ericson website and download your phone model manual.
Apr 05, 2009 | Sony Ericsson G502 Cellular Phone
GPRS of my N70 phone needs to be activated.How?
For this you have to contact your service provider. FOr example if you are using vodafone then you just contact any vodafone dealer or call customercare asking for this.They will send you the setting so u'll have to save it n set as default settings when askd.Now you are having the interne connection.Also u might need the pin number for saving the settings.Default pin is 1234 or 0000.If you are not sure which pin number to use ask cuctomer care for your pin num,ber as it will depend on your simcard n not your phone.
Feb 11, 2009 | Nokia N70 Cellular Phone
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
Jan 10, 2009 | LG Shine KE970 Cellular Phone
Cell Phones Logo
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
