Question about Laser Canon imageCLASS 8180C Multifunction Printer
I send or try to copy a document on the 8180c printer, it sets out the paper, but there is no image on the paper
  • 42 Answers
If this was the case all the time, I would imagine you have an incorrect driver in the Laser Printer. You should be able to upgrade the drivers by contacting the the Canon Co.
If this is a new problem the static bar that runs across the drum has lost it's positive charge to produce the picture should be replaced ... its not cheap !
Posted on Jun 19, 2009
On a Canon MF 8180c Image class 4 in 1 printer how do I get rid of the message that says hang up the phone & there is a green light flashing beside the copy button
got to control panel in computer , open up printers and faxes and clock on the printer. open up jobs in progress and if there is still something to be printed, delete it and go back to the print document and redo it.
Apr 22, 2015 | Canon Office Equipment & Supplies
Tip
Troubleshooting MINOLTA DI 1611, DI 2011
The copy is too light. The copy density is set too
light.
Use the Auto/Photo
key to select a darker
copy density .
The copy paper is damp. Replace the paper.
The copy is too dark. The copy density is set too
dark.
Use the Auto/Photo
key to select a lighter
copy density .
The document was not
pressed close enough
against the Original Glass.
Position the document so
that it is pressed closely
The copy is blurry. The copy paper is damp. Replace the paper.
There are streaks through the
copy.
There are specks throughout
the entire copy.
The Original Glass is dirty. Wipe the glass with a soft
dry cloth.
The document pad is dirty. Clean the document pad
with a soft cloth dampened
with a mild detergent.
The original is highly
translucent, such as diazo
photosensitive paper or
OHP transparencies.
Place a blank sheet of
paper over the document.
A double-sided document is
being copied.
If a thin double-sided
document is being copied,
the information on the back
side may be reproduced in
the copy. Use the Auto/
Photo key to select a
lighter density for the
background.
The Imaging Unit has
reached the end of its
service life.
Contact your service
representative.
on Dec 18, 2009 | Office Equipment & Supplies
Center images
>> Check the paper is correctly inserted in the printer tray
>> Set guides exactly to paper size (Ex: A4 Paper Size)
>> Copy paste the image into a word document
>> Select the document press Ctrl+E in Microsoft Word
>> Try to Print.
Mar 23, 2014 | HP Photosmart C3100 series
Hp photosmart c310 phot images don't center properly on page
>> Try to Print.
We have a Canon imageRUNNER 3230. Starting this morning, it has been printing everything off center. If you send a document to the copier for printing, it shifts the image to the left so that the far...
I would make sure that the paper guides in the paper tray are tight against the paper. And make sure the adf guides are close togather so the paper will not go in crocked Good Luck.
May 20, 2013 | Canon imageRUNNER 3230 Black and White...
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
I have a Lexmark mode lX3550. What do I have to do to make it fax?
Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. • The Lexmark Fax Software is installed on your computer.
Sending a fax using the software You can scan a document to the computer and then fax it to someone using the software. 1 Load an original document facedown on the scanner glass. 2 From the desktop, double-click the Lexmark Imaging Studio icon. 3 From the left pane of the Welcome screen, click Fax. 4 Select the Document option. 5 Click Start. 6 Enter the recipient information, and then click Next. Note: A fax number can include up to 64 numbers, commas, periods, and/or these symbols: * # + - ( ). 7 Enter the cover page information, and then click Next. 8 If there are any additional documents that you want to send with your fax, add these now, and then click Next. 9 To send your fax: • Immediately-Select the Send now option. • At a scheduled time: a Select the "Delay sending until" option. b Set a time and date. 10 If you want a paper copy of your fax, select Print a copy of your fax. 11 Click Send.
Aug 11, 2011 | Lexmark X3550 All-In-One Printer
I have an HPPhotosmart C5280. I want to print on an evelope 8.2 x 5.5 for a wedding invitation. The printer tells me paper mismatch every time I try it. I set it up every time on the computer, it prints...
The easiest way to print an envelope is to use Microsoft Word. If you have the software installed, go to start and then create new office document and click blank document. When the document opens, click on help and type in envelope. This will give you instructions on how to create an envelope and save a copy to your document. When you save a copy to your document, it gives you a picture of an envelope which helps to create it. Then click on file, and slide down the print and click ok. Creating the envelope through Word helps to change the printers paper settings. Word will send a signal to the printer to tell it what type of paper and size of envelope you are creating.
Hope this helps?
Jul 18, 2011 | HP Photosmart C5280 Printer
Line is appearing on the printed copies. How to
Is it a white or black line?There can be a piece of paper in the drum cartridge or the drum is damaged!Scratched!Try replacing the drum cartridge!Good Luck!
Dec 07, 2010 | Laser Canon imageCLASS 8180C Multifunction...
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Laser Canon imageCLASS 8180C Multifunction Printer Logo
251 people viewed this question
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
