Question about Mitsubishi WD-65833 65" HDTV
Wd-65833 light engine - Mitsubishi WD-65833 65" HDTV
3 Suggested Answers
  • 679 Answers
SOURCE: On my mitsubishi wd-65833 the timer light stay
This problem sounds like it could be an intermittent ly malfunctioning component in the power supply section of your TV. I suspect it could be a capacitor that is failing. This is quite common in televisions today. If you want to at least take a look at what could be wrong, unplug the TV take the back off and look at the power supply board for vented or bloated capacitors. Capacitors are can-like components the have tops that look they are made to open. If the top looks curved in any way that capacitor has to be changed. I suggest that for the repair of this TV you seek the help of a TV technician, due to the fact that the technician would have all of the tools need to properly preform the needed repair.
Posted on Feb 02, 2011
  • 63 Answers
SOURCE: how much would to pay
Between 100-500 check ebay
Posted on Feb 22, 2011
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
WD-65833 and SC-PT750 DVD has sound no picture
double check connections, try another input / output.
Jun 07, 2008 | Televison & Video
Wd-65833 has black spots
This is the DLP chip failing. Contact Mitsubishi and they will provide the part but you have to pay $200 for the service call.
Apr 17, 2012 | Mitsubishi WD-65833 65" HDTV
Mitsubishi WD-65833: Reset system on my WD65833 after replacing the DMD chip. Now get a flashing code of 1-2. Any suggestions?
You are not the first person I have seen who replaced the display chip and had fubar after--1,2 is no error found.
You might want to do a little more research: Mitsubishi when changing the optical engine has a procedure so the engine can communicate with the digital circuit in the set--opps!
By the way the reset on the front is only a boot up for the set--set also has a hidden option menu for a hard reset of the entire set to factory defaults.
tried that one?
Mar 31, 2012 | Mitsubishi WD-65833 65" HDTV
I have a mitsubishi wd 65 837 and it has white and black spots on the left side of the tv , can it befixed ?
I just had this happen to my wd-65833. It is a faulty dlp chip (they call it dmd board). I called Mitsubishi and they covered the cost of the part but there is a $200 service fee for the technician, no they will not send it to you. Support Service Mitsubishi TV
Sep 06, 2011 | Mitsubishi WD-65833 65" HDTV
On my mitsubishi wd-65833 the timer light stay solid. why?
Feb 02, 2011 | Mitsubishi WD-65833 65" HDTV
No DM Board on WD-65833
The Main Board contains the DM circuitry. And you are right, this board does not fail in the way of its predecessors. What is the unit doing?
Apr 30, 2008 | Mitsubishi WD-65833 65" HDTV
WD-65833
The Main Board contains the DM circuitry and does not fail in the same way as it's predecessors. What is the unit doig?
Apr 29, 2008 | Mitsubishi WD-65833 65" HDTV
WD-65833 Flashing Green Light/Will not turn on!
its an easy repair however i would recomend not even attempting the repair without the service manual as the DLP chassis is completely incased and you will need the info just to get the chassis out , That will explain exactly how to disassemble. once disassembled there are 4 100uf capacitors that are causing the problem. If you would like the full service manual for your set let me know and I will post a link where you can get it emailed and they will provide free support to help you do the repair.
Mar 29, 2008 | Mitsubishi WD-65833 65" HDTV
Mitsubishi WD-65833 65" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
