Question about Boating
Change are there any vidios for changing from in to an outboard on a23 ft trophy
    Top Expert:
  • Boating Master
  • 51,506 Answers
Not that I am aware of but that is a major task. patching the transum good enough to support the size outboard you want to mount .best left to a professional in my oppinion
Posted on Apr 23, 2014
How to change the throttle cable on my seagull outboard?
Remove the screw on the top of the throttle lever and insert the end of the new cable. Remove the top of the carb by unscrewing it and remove the cable and insert the new one with adjuster.
Here are the cables complete
http://www.sheridanmarine.com/product/british-seagull-outboard-throttle-cables
Here are some videos and one guy says he has changed his.
change the throttle cable on my seagull outboard Google Search
Nov 24, 2016 | Boating
2002 triumph trophy front wheel axle but torque
Hi, Mark 45-50 ft lbs. and I am sorry you can't find the first and best tool you ever bought for your Iron Horse but despair not for a mere $00 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day. DOWNLOAD 2002 Triumph Trophy
Oct 31, 2015 | Triumph Motorcycles
What is the difference between A23 and A23S 12v batteries?
batteries come in different configuration as to where the positive and negative poles are placed on a battery
the difference between a23 and a23 s could be which sides of the battery top the terminals are configured
it will not matter if you are just using it for power for door chimes
Oct 20, 2015 | Cars & Trucks
How to change 2007 dodge 1500 front struts?
Removal & Installation Independent Front Suspension – 2WD Vehicles To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Safely raise and support the vehicle.
  3. Support the lower control arm outboard end.
  4. Remove or disconnect the following:
    • Upper shock absorber nut, retainer and grommet
    • Lower nuts and shock absorber
To Install:
  1. Install or connect the following:
    • Lower retainer and grommet on the shock absorber stud and insert shock absorber through frame bracket hole
    • Lower nuts
      1. Torque to: 25 ft. lbs. (34 Nm)
    • Upper grommet, retainer and new nut (or existing nut with Mopar Lock N Seal or Loctiti 242) on the shock absorber stud
      1. Torque to: 40 ft. lbs. (54 Nm)
  2. Remove support from lower control arm outboard end.
  3. Lower the vehicle.
Independent Front Suspension – 4WD Vehicles To Remove:
  3. Remove tire and wheel assembly.
  4. Support the lower control arm outboard end.
  5. Remove or disconnect the following: dod_ram15_02-04_4wd_shock.gif
    • Upper shock nut with insulator and retainer
    • Lower shock bolt
    • Shock absorber
To Install:
    • Upper part of shock absorber into frame bracket with insulators and retainers and nut
    • Lower part of shock absorber into lower control arm with the bolt
      1. Torque to: 100 ft. lbs. (135 Nm)
  2. Remove support from lower control arm.
  3. Install tire and wheel assembly.
  4. Lower the vehicle.
Link/Coil Front Suspension To Remove:
  2. Remove or disconnect the following:
    • Nut, retainer, and grommet from upper stud in engine compartment dod_ram15_02-04_shock.gif
    • Nuts from upper shock bracket
  3. Lower bolt from axle bracket and shock absorber from engine compartment
To Install:
  1. Position lower retainer and grommet on upper stud and insert the shock through the spring from the engine compartment.
  2. Install or connect the following:
    • Lower bolt
    • Upper shock bracket and nuts
      1. Torque to: 55 ft. lbs. (75 Nm)
    • Upper grommet, retainer and upper shock absorber nut
      1. Torque to: 35 ft. lbs. (47 Nm)
Jul 22, 2010 | 2007 Dodge Ram Truck
I have the80022D11 in the ps3 what to do
Once this occurs, trying to load a save file for a game that supports trophies will give you the option to either start over (wipe the save file) or sync trophies (which fails). At this point trophies will no longer work and save game files for any game that supports trophies will no longer load. The only work around at this point is to delete your PS3 user account (not to be confused with your PSN user account) and create a new one (which you can link to your existing PSN account). Once this is done your trophies will sync, but you will lose all your saved games. If you try to restore any saved games you made before doing this, the error will occur again. The problem appears to be triggered if the user changes his/her email address or password using the XMB account management tools. So until Sony fixes this problem, users should not change their PSN email address or password.
Mar 02, 2010 | Sony PlayStation® 3 (60 GB) Console
Will not run if gas tank isn;completely full 2000 triumph trophy 1200
You need to flush out the gas line and change the gas filter.
Jul 06, 2009 | 2002 Triumph Trophy 1200
Vidio player toshiba v631 snowy all the time stand by
You need to clean the video heads and change the push buttons that not work
Jul 05, 2009 | Televison & Video
Change the video input
The button may be defective or you may need to use the remote to select the input source. ie vidio line in or vidio 1
Feb 28, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Boating Logo
41 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
