Question about Raypak 2100 Pool Heater Gas 336000 BTU' (Pilot Light) ()
Raypak 2100 temp sensor failure light is on - Raypak 2100 Pool Heater Gas 336000 BTU' (Pilot Light) ()
    Top Expert:
  • Raypak Master
  • 4,292 Answers
Replace temp sensor
Posted on Apr 27, 2016
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: Raypak 2100 ignites then it turns off or shakes bangs HL1
Check the bypass in the header for damage. HL1 along with the banging/popping is too low of water flow through the heater and the water is getting to hot.
Posted on Sep 07, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
  • 990 Answers
SOURCE: Raypak 2100 digital display on start up goes through
There may be a buildup of carbon on your pilot or your gas pressure may be low. It is hard to say without more info on the heater, gas line size and meter size. Depending on where you live it could also be something like spider webs in your gas orfaces. These will cause all to fire normally but not be consistant enough to read fire back to the ignition control. A small piece of bent wire into the orfaces will help to clear this up. As it is not a heater related problem it will not show a ready made answer on the display. Hope this helps, let me know.
Posted on Nov 07, 2009
What is a high limit condition
temp sensor failure. when sensor read temps that are way too cold or way too hot
Apr 21, 2014 | Raypak 2100 Pool Heater Gas 266000 BTU'...
HOW DO YOU REPLACE A WATER TEMP SENSOR ON RAYPAK 2100 336A POOL HEATER
remove side by plumbing it has wires going to it and threaded into header
Mar 30, 2013 | Raypak Pool & Spa
I have a RP 2100 Raypak Pool Heater Model number C-R185-EN installed about 1996 and used very little through out the years the front service light is on-- red --the back circuit board fault shows a sensor...
The part number for the thermistor for your heater is 005299B, officially called the temperature sensor IID it is also refered to a temp sensor or temp sensor kit.
John
Jul 09, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 Pool Heater  Gas 336000 BTU' (Pilot Light) () Logo
62 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
