Question about Connex 3300 240-Channels Base CB Radio
Cx-3300 low output on low and high power - Connex 3300 240-Channels Base CB Radio
The switch for low and high power the contacts are gone or you need to check the DC voltage to the output section and the voltage drop on TX usually the likes of the cobra 148GTLDX has a bridge board you can remove and add some LCD DVM for current monitors and setting of bias etc so perhaps a regulator has failed or a resistor or the contacts on the switch you need to trace it out using current readings
Posted on Nov 23, 2014
2 Suggested Answers
nadasei12
SOURCE: I need an owners manual for a cx 3300 hp
Hi you can find the owner's manual at cb http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf tricks.com . Great source to find about cb radios.Visit my store at http://www.jokermanelectronics.com/Have a great day!!
Posted on Mar 29, 2012
Harley trouble codes A1A9
For 2000-2004 Sportsters, there are only 7 different codes.
d01 - Speed sensor power output shorted low
d02 - Speed sensor power output shorted high or open
d05 - Speed sensor return shorted high
d06 - Speed sensor return shorted low
d08 - Speedometer power over voltage
d09 - Speed output shorted high
d10 - Speed output shorted low or open
I don't see your code here.
Aug 07, 2014 | 2004 Harley Davidson XL 883 Sportster
Canon ir 3300 shows on error code e000064 how to solve this problem
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
Possible causes:-
The contact has poor connection.
The wiring is faulty.
The composite power supply PCB is faulty.
The DC controller PCB is faulty
I would start by cleaning the contacts and the corona wires.
Jun 29, 2014 | Canon (6981A002AA) for imagerunner 2200,...
Radio want stop scanning
your keyboard membrane is needing cleaned with IPA you must have spilled coke or pepsi or somthing conductive on its membrane so i would just look to replace it you need to perhaps replace some capacitors in the controller board section {mpu for it} i think dry caps cause this esp low value ones around the mpu
Apr 24, 2014 | Connex 3300 240-Channels Base CB Radio
Connex 3300
sounds like a power amplifier failure. have the rig serviced
Apr 21, 2014 | Connex 3300 240-Channels Base CB Radio
I have an avr 3300 that I rarely use out of the blue one day I turned it on and found that the low end responce was all but non existant. It still has plenty of output but it sounds as if someone took and...
You can only use the tone control and channel volume at the bottom right corner of the front panel. Push them and use the select knob to increase. Push the "surround perimeters" and select the one you like.
Aug 07, 2010 | Denon AVR-3300 Receiver
I get a code d09 does that mean my regulator is bad
No it does not, it means there is an issue with one of the speedometer inputs, see the chart I attached to help you understand.
SPEEDOMETER TROUBLE CODES
CODE - TROUBLE - WIRE COLOR
d01 - speed sensor power output shorted low - red
d02 - speed sensor power output shorted high - red
d03 - not used
d04 - not used
d05 - speed sensor return shorted high - white
d06 - speed sensor return shorted low - white
d07 - not used
d08 - peedometer power overvoltage - orange/white
d09 - speed output shorted high - white/green
d10 - speed output shorted low or open - white/green
5 digit number - speedometer pulses per unit
Jun 14, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
1981 CX 500 Custom. No power to the headlight. low beam or high beam. need a wiring diagram or some idea of what to try.
Without the book you can look at the wire color including any secondary marks like the different color line on the side of some of them,at the start lets say in the headlamp connector,note what they are and look along the wire harness untill you see these same gague and colors you started with test to be sure, no battery power should be hooked up while u are doing this.as u need to be able to use multimeter to test for continuity, ground or open circuit. first thought i had was check fuses.if they are good test for 12 volt on headlamp wires, if they have power the bulb may be bad. to test lamp with meter set to cuntinuity watch for signal between the low and high beam terminals and the ground in the center, if none a bad bulb is what you have.
Apr 03, 2010 | 1981 Honda CX 500 B
How do you set regular channels and low and high on a connex 3300
Combination of hi / low switch and the band knob, I believe C band with the switch on low will give regular channels.
Jan 10, 2010 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
89 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
