Question about Hitachi CP-S240 Multimedia Projector
Hitachi cp-s240 blue tint cloud problem
I have hitachi cp-s240 projector, it shows a blue tint cloud when displayed to a screen. I have tested the vga cable and is fine. Can you tell me the problem?
  • 42 Answers
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
Posted on Jun 19, 2009
Hitachi CPS-220 is saying 'RGB is out of range' when connected to PC.
This would indicate that the display settings on the PC are outwith the acceptable range of the projector.
To solve this, right-click on a clear part of your PC desktop and select "Graphics Properties" (in Vista). You then need to adjust the display settings. That is a very old projector which will accept a maximum screen resolution of 1024 x768 pixels. Try changing that 1st. If it doesn't work, keep that screen resolution and also adjust the refresh rate in Hz until you get an image.
The native resolution of that projector is SVGA (800 x 600 pixels).
Feb 14, 2011 | Hitachi CP-S240 Multimedia Projector
Flip image on Hitachi CP S240
The setting you are looking for is called mirror. If you go into your menu, you should be able to find it. I'm not fmailiar with that exact model, but Hitachi is very good about keeping their projectors consistent where the menu/options are concerned. Once you find the mirror section, cycle through the options (there will be 3 or 4) until you find the one you need. If your projector is hanging upside down from the ceiling, select the ceiling option.
Feb 08, 2011 | Hitachi CP-S240 Multimedia Projector
The color on our cp-s240 projector is really bad. When I go to menu, color and tint are greyed out so I cannot adjust them, what should I do?
Often you will see that you have lots of options in your menu that appear grayed out. This occurs when you do not have an input device connected to your projector.
In order to have access to all the menu options, simply connect an input device (TV,DVD player, computer, etc) to your data projector and start the projector.
Assuming everything works properly, if the projector starts receiving a signal, you will have all your menu options available.
I'd also note that image discoloration can also be caused from defective/damaged cabling, cables not being connected fully, bent pins depending on the type of cables you are using, and also for internal problems. If you can not adjust your settings to achieve satisfactory color, check your cables for damage and make sure they are all connected properly.
Jan 05, 2011 | Hitachi CP-S240 Multimedia Projector
My Viewsonic PJ860 projector (aka Hitachi CP-S860W) has developed a condition in which there is a yellow vertical stripe down the right edge of the screen and a blue vertical stripe down the left side of...
It does sound like this is an alignment problem of the blue LCD or a problem on the main board controlling it. I am not sure if this is a field adjustable unit. A call to the authorized service center should provide that answer.
Aug 11, 2010 | Hitachi CP860960LAMP Projector Lamp for...
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Whats it mean when the projector says to check the airflow every few hours on the screen. The projector is a Hitachi CPX440
one or more of the fans may not be working properly and the heat is triggering the temperature sensor. if the projector is too dusty, the heat stays in and may ruin components. if there are filters, clean them first.
Nov 04, 2009 | Hitachi CP-S240 Multimedia Projector
Hitachi CP-S240 Multimedia Projector Logo
873 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
