GPs coords from this bunch of words - ABIRZOREBFFPNUIVXGNURPXBUZVXROENUIBURPXBUEBJZRBUSBXFGEBGBFFPNUJVFFXRLRPXBUEBJZRBUFRRN VEENUVAQRRNURPXFENLQRYYGNURPXBUTBYSEBJZRBURPXBURPXBUFRRNVEENUSBXFGEBGBFFPNUJVFFXRLR PXBUEBJZRBUABIRZOREVAQRRNUABIRZORERPXBUEBJZRBUCNUCNUBFFPNUVAQRRNUABIRZOREGNATTBGNA TTBEBJZRBURPXBURPXBUABIRZOREVAQRRNUABIRZORERPXBUEBJZRBUGNATTBEBJZRBURPXBURPXBUOENUIB ULNATXRLJVFFXRLVAQRRNUFRRNVEENUFRRNVEENUXRLYBURPXBULNATXRLJVFFXRLBBARRSBEZABIRZOREJVF FXRLBBARRSBEZABIRZOREGNATTBEBJZRBURPXBURPXBUQRYYGNURPXBUTBYSEBJZRBURPXBURPXBUFRRNVEE NUSBXFGEBGBFFPNUJVFFXRLRPXBUEBJZRBUNYSNUVAQRRNUGNATTBCNUCNUBFFPNUVAQRRNUABIRZOREG NATTBGNATTBEBJZRBURPXBURPXBUMBBYBBRPXBURPXBUEBJZRBUBFFPNUGNATTBBFFPNUBFFPNU
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
Why is my coordinates off by 50-80ft. why? Side by side comparision of another gps shows my gps is not accurate.What do I do?
Your GPS is accurate for that brand. I have a Lowrance I Finder Pro. We could both put in the same coordinates and come up in different locations. It is just the way the different GPS's get their signal from the satellite. I use my GPS most of the time for a sport called Geocaching and so when I am given coordinates and don't find the thing I am looking for I so about a 30ft-60ft search around where my GPS took me. So yours is basically doing the same thing. I wouldn't worry about it......it's just the way the different models receive the signal that thows them off a bit. If you went out and got a set of coordinates and then I put those same coords into my GPS I would arrive at a completely different location as you. All is well....no need to worry.
Aug 07, 2009 | Garmin eTrex Legend Cx GPS Receiver
WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Jul 04, 2009 | Western Digital My Book Essential Edition...
I coudn't find the street Saujana impian in selangor
many mapsare almost 12 months behind, so if the location is new or only in the last 12 months it will be on the next issue.
Also sometimes different companies program data differently to some boundaries. Look the address up on google earth and ensure you are asking for the right area. If it can accept coordinates use the coords fro G/earth and see if it can then find the place you are looking for
Jun 22, 2009 | GPS
Garmin Nuvi 205 WIll not power on
Press and hold the reset button with a ball point pen for eight seconds.
The reset button is nearly invisible. On the bottom of the unit is a grey label with a bunch of writing on it. There's a little splotch of printing with a circle, crosshairs, and the word "Reset." You'll ahve to look carefully. You can't actually SEE the button. It's beneath the circle on the label.
Use a ball point pen, press in at the circle and hold for eight seconds.
Jun 11, 2009 | Garmin nuvi 205 GPS Receiver
Brand new only month old Nuvi 205 and ont turn on no reset button
I had the same problem.
Jan 18, 2009 | Garmin nuvi 205 GPS Receiver
No display after that
Ok shut it off and take the coords out make sure you re-connect the coords back and try it again.. This should fix it! It tooke me 8 times the other day to get a display so i am hoping it works let me know!
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Custom voices
You cannot customize the voices on this, or any other Garmin product of which I am aware. The Tom Tom Go 720 will allow you to record your own (or someone else's) voice on the unit (50 different phrases). However, any unit with the Text-to-Speech feature (which is what gives you the spoken street names) utilizes computerized voices to put the words together, which is why some sound "garbled." No unit does this better at this time. Tom Tom's pronunciations are, in my opinion, worse if anything (Branch instead of Bridge when abbreviated "Br", Crossing Island Parkway instead of Cross Island Parkway, etc.).
Dec 30, 2007 | Garmin StreetPilot c550 GPS Receiver
Won't give me the correct location
you should search for mapdate (kaartdatum in dutch) and select WGS84, it's a preference all geocachers use
Nov 27, 2007 | Garmin eTrex Legend GPS Receiver
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
