Question about Singer 5050 Mechanical Sewing Machine
Singer simple machine: buttonhole maker stitches in same place.
At the beginning it will not advance to left side to continue buttonhole, so will not do the top neither, the right side.
    Genius:
  • 1,788 Answers
Have you read your manual and made sure that the buttonhole lever is pushed to the rear? Call Singer if you still have a problem, 1-800-4singer. Good luck
Posted on Aug 27, 2010
My singer 6160 needle is not centered anymore. It is slightly to the left. Can I readjust to be centered once again?
yes, those needle bars can be adjusted. try switching from buttonhole maker to straight stitch. When making buttons it will move to one side or the other, if no button hole maker, switch to zig zag and back to get the needle to reposition.
Jul 29, 2017 | Singer Sewing Machines
How do I fix a onestep buttonhole that is sewing only on one side?
I am giving a link for the basics of a one step button hole. Next time include the machine make and model for addtional help.
One Step Buttonholing
Mar 01, 2015 | Singer Sewing Machines
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
Buttonhole making instructions from the manual of the Singer Simple do not seem to be accurate. The tension is incorrect and the machine is only sewing down one side without creating the satin stitch/...
Some machines will start out by sewing a straight stitch all the way around the buttonhole area first and then will zigzag/satin stitch along the sides. Bar tacks will be the last stitches sewn - hope this helps!
Nov 09, 2009 | Singer 3116 Simple
Buttonholer operation
push the lever back, look at your manual and you will see what I mean. Read the manual and watch the dvd and you will see what you are doing wrong.
Apr 10, 2009 | Singer 3116 Simple
Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual. 1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
Mar 28, 2008 | Singer 7422
3rd step of buttonhole doesn't work
Souds like a stitch balance problem how long since the machine was serviced as the buttonhole mechanism can seize up if not used frequently.
Mar 17, 2008 | Husqvarna Daisy 310
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Buttonhole
I'm afraid that you are unable to correct this glitch on your own. Any sewing machine service center/shop will do...call around and look for the shop with the lowest 'minimum' charge. It is such a simple fix. However, although simple, the adjustment is so incrementally precise that without thorough understanding, your stich patterns could be rendered unuseable. I have no idea of the current value of your sewing machine, but if you deem the repair costs prohibitive, there is a workaround so you can complete your buttonhole. Complete your buttonhole setup as normal. I assume that you run tests first to adjust your stitch length/density of the buttonhole using the Step 1 setting. When you find the the length/density that you want, using an ink marker/crayon...whatever...being as precise as possible, mark a linear line from the edge of your length selector dial, continuing to the body of your machine. Now, select Buttonhole Setting #3, and increase the stitch length until you see the length/density that you want. Find a clear spot on your length dial and repeat the marking procedure. When you are ready to make a buttonhole, align the markings for Buttonhole Step 1 on your stitch length dial and proceed, complete your tack of step 2, stop, manually raise your needle out of the fabric using the balance (hand) wheel on the right, adjust your stitch length dial accordingly for Step 3, then on to your final tack #4. If it's only your buttonholer that is giving you trouble, take the extra 15 minutes or so, and use the workaround and mark your machine. It doesn't have to be ink, it can be pinstriping tape...whatever, and spend the money you saved on fabrics and notions instead.....good luck my friend.
Jul 27, 2007 | Singer 2732 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
344 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
