Question about Raypak 2100 Pool Heater Gas 266000 BTU' (Pilot Light) ()
Raypak 2100 what is the temp sensor
Temp sensor failue
    Top Expert:
  • Raypak Master
  • 5,045 Answers
Replace temp sensor
Posted on Apr 27, 2016
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: Raypak 2100 ignites then it turns off or shakes bangs HL1
Check the bypass in the header for damage. HL1 along with the banging/popping is too low of water flow through the heater and the water is getting to hot.
Posted on Sep 07, 2009
  • 990 Answers
SOURCE: Raypak 2100 digital display on start up goes through
There may be a buildup of carbon on your pilot or your gas pressure may be low. It is hard to say without more info on the heater, gas line size and meter size. Depending on where you live it could also be something like spider webs in your gas orfaces. These will cause all to fire normally but not be consistant enough to read fire back to the ignition control. A small piece of bent wire into the orfaces will help to clear this up. As it is not a heater related problem it will not show a ready made answer on the display. Hope this helps, let me know.
Posted on Nov 07, 2009
What is a high limit condition
temp sensor failure. when sensor read temps that are way too cold or way too hot
Apr 21, 2014 | Raypak 2100 Pool Heater Gas 266000 BTU'...
HOW DO YOU REPLACE A WATER TEMP SENSOR ON RAYPAK 2100 336A POOL HEATER
remove side by plumbing it has wires going to it and threaded into header
Mar 30, 2013 | Raypak Pool & Spa
HOW DO YOU REPLACE WATER TEMP SENSOR ON RAYPAK 2100 336A GAS POOL HEATER
open side by plumbing it has wire going to it and threaded into header
Mar 30, 2013 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 Digital, water temp sensor wires keep burning
It should be insulated around the outside of the fire compartment. If that area is getting that hot it may be a result of "rollout" where the fire gets outside of its normal area chasing the oxygen path.This is a result of a clogged heat exchanger Take the lid off and make sure that the exchanger is clear of debris and the baffles are in good condition. If you see a lot of soot (sometimes deposits are large enough to bridge the copper vanes in the exchanger) It needs to be cleaned. Sooting is an issue mostly attributed to insufficient gas supply. Main culprits are an undersized gas meter, or too small pipe diameter, or too long of a run from the meter.
Dec 14, 2012 | Pool & Spa
Raypak 2100 Pool Heater  Gas 266000 BTU' (Pilot Light) () Logo
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
