Question about Acer Aspire 3610 Notebook
My battery will not charge. Is there a battery setting on the bottom of the computer that disables the battery from re-charging when plugged into an outlet?
  • 674 Answers
ACTUALLY NO.. IF THE BATTERY NOT CHARGING THAT IS CHIPS PROBLEM FROM THE BOARD.. OR YOU BATTERY SOME PROBLEM TO CHECK THE CHIPS .. USE ANOTHER BATTERY IF ITS CHAGRING IT MEANS THE CHIPS IS NO PROBLEM ONLY THE BATTERY
Posted on Jun 19, 2009
Which batteries to use for hand set.rechargeble or otherwise
use the same type of rechargeable batteries it came with. not all rechargeable batteries need the same type of charger. make sure the charging station is plugged in, and see if the charge light is on on the phone. phone light should lite up should when placed in the charger. if not... see if the plug in transformer is putting out the needed voltage, center of plug is "+" if dc voltage. also make sure that plug in into the bottom of charging station tightly. also make sure the batteries if separate cells are in the phone correctly. springs go to the smooth bottom end which gets inserted first.
Feb 27, 2015 | Lands Phones
My computer is not charging and i dont think its the battery maybe a lose connection or broken not allowing a flow to the battery
I understand that the Notebook battery is not charging. The information is model specific as there are power management software in most of the computer. This power management software can to set to disable the battery charging. However, the general steps is to remove and reinsert the battery and make sure that the power is reaching the notebook from the wall outlet.
You may revert back with the model for more information.
Nov 14, 2013 | Computers & Internet
Battery status incorrect
This recalibrate's the battery.
Charge the battery completely. Monitor the battery indicator, which is usually found that the bottom of your computer screen, to check if the battery is already fully charged.
Plug off the power adapter and use the laptop until the battery is completely drained. To drain the battery faster, run several programs at once and keep the contrast of your screen to its highest levels. Turn off all power-saving features as well. Turn off sleep mode.
Make sure that the battery is totally drained by waiting for your laptop to shut off or go into sleep mode automatically because of very low battery charge.
Plug the power adapter again and charge the battery again completely. Once this is done, restore the power-saving features and adjust the contract settings of your screen to normal.
Apr 08, 2013 | Dell Vostro Computers & Internet
Laptopp plugged in not charging
What's your OS? Someone claimed to have resolved this problem following the steps below:Shut down Computer. unplug AC. Take out battery. Plug in AC. Start up computer. Disable Microsoft ACPI CC Method Battery Shut down computer. Unplug AC. Insert battery. Plug in AC. Turn on. Enable Microsoft ACPI.
Then it was working.
Original post:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Of course, there were some different voice on this post. Have a read, and may this help.
Nov 20, 2011 | Computers & Internet
My Toshiba's laptop's sleep and charge USB port
It's possible to fix. First go to device manager and you should see something like "USB Root Hub". Double click to open it, go over to power management, and "Uncheck" "Allow this computer to turn off this device to save power". Do this for all that say USB Root Hub. Next go to "Power Options" then "Edit Plan Settings" (accessible through "choose when to put the computer to sleep") and select "Change Advanced Power Settings". Next, make sure you do this in all of your power settings, but scroll down to an icon called USB settings. Expand the selection, then expand the "USB selective suspend setting". Choose, both on battery and plugged in if you want, to Disable the selective suspend. Finish and apply. Also, to confirm, you know that the USB device (IPod) but be plugged into the eSATA port, correct? It doubles as a USB port and is the only one capable of charging.
Mar 29, 2010 | Computers & Internet
How to maximize battery life of a laptop
In addition to all these excellent suggestions don't plug your computer in with the battery installed every time you need to use it. Most manufacturers don't recommend uninstalling the battery (unplugging it) while using it. The truth is, though, this repeated charge and discharge cycle from plugging in your laptop will significantly drain the life of your battery because it is only good for so many charge cycles. So if you're in a situation where you don't need to use the battery unplug it and just use AC power. Also don't always run the battery completely dead when using it. It is best for modern li-ion batteries to be charged to full when they still have 15-20% power still left in them. About every 10 discharge cycles it is best to run the battery completely dead as this will reset the battery meter in the computer so that it can read the available charge more accurately.
Dec 12, 2009 | HP Pavilion dv6000z Notebook
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Not charging when it says charging
I was going to suggest a recalibrate might do this
with some machines run the battery to flat then fully charge at full charge shutdown and reboot windows.
With some machines the same thing is done as follows:
Enter the bios and disable the automatic shutdown for low battery. Disable the automatic shutdown for low battery in Windows. Run the laptop until it just dies from the battery going dead.
Charge the battery. Re-enable the automatic shutdowns.
And I believe some even have options in the Bios to recalibrate.
If this doesnt work then could be a voltage issue in the charger (is it universal with voltage settings?)
if it is this and no settings that could have been moved to wrong voltage etc, then maybe need testing and replacing.
Hope this helps
Jun 10, 2009 | Dell Inspiron 6400 Notebook
Charging is Disabled
i have tried different chargers, but my phone keeps saying abnormal state charging disabled.
Apr 07, 2009 | Samsung Cell Phones
Acer Aspire 3610 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
