Question about Air Tools & Compressors
Fluid fliud runs from tip
Why does transmission fliud over flow out filler tube
your transmission needs more help than you can give it . take it to a shop that can check the radiator cooling also
Mar 25, 2016 | 2000 Cadillac DeVille
How to check transmission cooler?
I wonder if the ****** is about to go out. Or a shift solnoid is hanging up. ****** shop your best beat.
Jun 15, 2012 | 1991 Plymouth Acclaim
Hand brake light on dash intermittant. Switch at hand brake is ok
check the brake fluid level. the brake fluid can be low and comes on when stopping or going around curves. the brake fliud level sensor uses the same brake light as the parking brake. if the fliud is low check the pads and /or shoes for wear.
Aug 07, 2011 | Toyota RAV4 Cars & Trucks
The fluid is below at min, which the mechani says is good for a mazda 3. Is that right?
As you didn't explain which fluid is low, here's a general explaination. There's always a cause for any fliud being low, the only fliuds that can fall below minimun levels are brake fliud [ as the brake pads or shoes wear it takes more fluid to push the surfaces together ] if not checked on a routine service, such as oil changes. The other is windshield washer fliud, which is lost with use.
Any other fliud loss isn't normal, and should be addressed.
Mar 27, 2011 | Mazda MAZDA3 Cars & Trucks
Transmission warning light coming on,possible problems are low oil pressure or no oil pressure how do i check which one it is and fix it? Thankyou
If you have an Automatic transmission. Lift the hood. Locate the Transmission dip stick. Start the engine and let the engine warm up some. then check the fliud level on the dip stick. On a Manual Transmission, locate the transmission under the vehicle and the fill plug (upper) and drain plug (lower) on the transmission. Remove the fill plug (upper) and see if fluid runs out. If no fluid runs out, add recommeded transission fluid until the fluid starts running out, the replace fill plug..
Jan 25, 2011 | Ford F Cars & Trucks
Where do you check the transmission fluid?
PERFORM AN ELIMINATION OF ENGINE FLIUD CONTAINERS TO ACQUIRE THE TRANSMISION CHAMBER
The vehicle should only have an engine oil compartment, radiation compartment for antifreeze/ water, power steering fliuds, a water wiper blade spray dispenser compartment, and finally the transmittion fliud container area all situted within the engine entrapment area. Usually, opening the engine for the first time would require observing the fliud compartments that are identifyable from the remaining engine chambers. Observing closely on the fliud container should have written descriptions of what is expected within compartment. For example, the water fliud containers for wiper blades would usually have written lables as wiper blade fliud container, radiantion container would usually have the antifreeze demarkation logos visibly observable when engine is opened. Rely by elimination methods to ascertain the transmission fliud compartment. For example, once antifreze container, wiper water container, engine oild container, power steering fliud containers have been identified, the most like only remaining in the engine would be the transmition fliud compartment. Alternately, every fliud container within the vehicle engine is situated at separate areas. For example, the only fliud container closest to the transmittion chamber is the engine oil compartment. The vehicles usually require more engine oil than transmission fliud. Between both fliud containers, the smallest chamber for fliud oil is usually for transmission perposes in the absence of hydraulic fliud compartments with newer vehicles.
Jan 22, 2011 | 2000 Oldsmobile Alero
Fluid leaked on belt; car won't fully crank;how do i get to run?
check you crank sensor wiring. wires run from behind a plastic cover up and out towards the radiator. good luck
May 25, 2009 | 1991 Buick LeSabre
Washer fluid not working
Remove the pump from the tank and make sure there is no junk stopping up the pump.
allso if the pump does run and there seems to be no stoppage,then replace pump.
running dry some times damagers the impellar that pumps fliud.
Please rate this solution
Dec 17, 2008 | 1998 Chevrolet Astro
Transmission slips
Look usally when they start slippin,,, its gettin close to getin a rebuild,, but not always ,,it could have old transmission fliud in there. you can change the transmission fliud ,, thats should help,see it could be cloged up,, change fliud and the filter in tranny,, ,,cheaper than a transmission,, ,goodluck
Oct 05, 2008 | 1996 Jeep Cherokee Country
Leaking fluid
it could be your automatic transmission fliud. normally this fluid is color red. have it checked right away because you may have bigger problems if you ignore it.
you can check your level by running the truck on neutral and check your dip stick on your transmission fluid.
tnx 4 using fixya.
drcool
Aug 24, 2008 | 2005 Ford Escape
Air Tools & Compressors Logo
24 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
