Question about True Sandwich Unit - TSSU-27-12M-C
Problem with Thermostat (Ranco A30-2210 spec'ed for 30 - 43F) on
Thermostat(Ranco A30-2210 spec'ed for 30 - 43F) on True Sandwich Cooler.
The capilary sensor is inserted into small tube mounted along upper evaporator part way.
Insertion lenght identical to what was found when exchanged, about 20 inches etc.
The compressor does fine until the lowest Dial setting is being attempted.
The signal from the TSTAT is then cycling too often and temp does not go down past 40F in space.
Target is 33 to 38 F
Plugging in Comp direct in uncontrolled Outlet brings temp down, no problem.
What do I miss here?
Why is there an apparent block to lower temp...
what causes that cycling of TSTAT?
rockitman187
  • 2559 Answers
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
Posted on May 03, 2009
SOURCE: how to mesure the lenght and size of capilary,is
how to mesure the length and size of Capilary 1/4 Hp Compressor R-12 volt 220 ho
Posted on Jul 15, 2009
  • 88 Answers
SOURCE: Tru GDM-47 cooler evaporator icing up.
possible bad defrost timer,or control on an off is bad,were you adjust temperature...thermostat from 30 to 65.00 dollars....possible there is leak or unit is under or overcharged..more than likely under charged...possible defrost heater is not working...good luck..michael doctor airr appl.repair..service tech..843-384-8474...call if need additional help ..its free..
Posted on Mar 27, 2010
  • 1262 Answers
SOURCE: I got a true refrigeration sandwich prep table it ...
Look for doors not properly closing, poor air flow over coil or something blocking air flow, improper freon level.
http://www.truemfg.com/pdf/InstallManuals/TPP_TSSU_TUC_TWT/tuc_english.pdf
check out this web site as it has a manual for your equipment. it has lots of good info. Hope this helps. If you need more help, let me know.
Posted on Jun 13, 2010
  • 216 Answers
SOURCE: I have a True GDM-10
Eric,
Thank you for choosing FixYa. I wanted to ask quickly, why are you using a Ranco temperature controller? According to the manual for this refridgerator (available here even though it doesn't have the model listed, this is what I got every time I searched for this model, so I'm assuming it's the same) on page 20, there is a procedure for altering the internal temperature.
You will need a philips screwdriver, a 5/64" or 2mm allen wrench, and a T-7 torx wrench (all available at home depot, etc). You'll need to alter the temperature by a +20 on the low end, and +33 on the high end. These are referred to cut out and cut in temperatures, respectively. Follow the instructions on the manual to remove the temperature control. Each quarter turn increases the temperature by 2 degrees, to to increase your cut out temperature (the low end) to 50 degrees, you'll need to turn the allen screw clockwise 10/4 turns, or 5 full revolutions. Likewise for the cut in temperature (the high end), turn the T-7 torx screw 6 full revolutions clockwise, followed by a quarter turn (to increase to 67). If you want it up to 68, give it another 1/8 turn.
You can fine tune the temperature (with a little bit of effort and time) by replacing the temperature module then using a digital thermometer to measure the temperature. If it's outside the bounds of your needs, take the temperature control back out and tweak the controls a bit. Clockwise is warmer, anti-clockwise is colder.
I don't know if this actually solves your problem or is impossible for you, but I wanted to let you know in case you weren't aware that this model has a built-in functionality for altering the temperature. The issue you're running into is that constant cycling of the compressor without allowing it to defrost every now and then is very harmful to the system and can end up burning out your compressor, leaving you with very costly repairs.
Also take a look at this document. It is a technical service document for GDM models, and may contain some very good information. It sounds like you are fairly mechanically inclined, so I don't believe that you should have any trouble following the instructions.
Hopefully I could help, let me know if there's anything I didn't answer or anything else I can tell you!
Tj
Posted on Jul 26, 2011
How to check thermostat ?
You might try a tutorial by Ranco controls on YouTube. Trying to explain taking it out putting it in a glass of water with ice and salt and checking for continuity is probably easier to watch than reading my attempt. Hope this helps and good luck.
Jun 10, 2014 | TRUE TSSU6016
Danby dwc 044 wine cooler compressor is very hot to the touch. What could be the problem? relay?
check compressor relay..
also ok so check condenser coil heat no heat so check gas lickeg on capilary tube or" condenser lickeg or" jam capilary tube.
May 30, 2012 | Danby DWC044BLP Wine Cooler
I own a true 2 keg beer cooler and it has recenty been not able to turn off the cooler and freezes the beer. is this a problem with the thermostat or something else?
This is probably the thermostat stuck closed and bad. Turn the tstat all the way to left or counter clock wise. The compressor should turn off.If the compressor continues to run the tstat is stuck and bad. A good replacement tstat would be Ranco # A12-1560.
Nov 08, 2009 | True TD-50-18 Beverage Cooler
Fridge is too cold even at lowest setting and freezing drinks.
The thermostat sounds like it is out of calibration and stuck closed. A good replacement would be a Ranco A12-1560 mounted in the evaporator (cold) coil.
Nov 07, 2009 | True TBB-3G-S Commercial Refrigerator
The fridge freeze the food
The thermostat is probably stuck closed and bad. A good replacement would be a Ranco A12-1560. If its not the thermostat there may be a stuck relay on newer modes coolers.
Nov 05, 2009 | True GEM-23
NEED CAPILARY TUBE. WHAT SIZE HOW LONG. TRUE
have ready a correct make and model number and call 1st source at 1-800-392=3939. if u can't get it there, who knows. plz rate me.
Jul 27, 2009 | True 23 cu. ft. / 651 liter Commercial...
TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MINUTES.SEEMS TO COOL FINE MAINTAINS 38 DEGREES, OTHER TRUE COOLER WE HAVE DOES NOT DO THIS...ANY SUGGESTIONS?
May 03, 2009 | True Refrigerators
Salad prep cooler too cold I turn the t-stat up or down compressor still running I think the t-stat is bad don't you think?
It sounds like the thermostat is "stuck closed". Try unplugging the cooler, MAKE SURE ALL POWER HAS BEEN DISCONECTED. Remove thermostat cover with thermostat on it. Carefully pull one of the wires spade connectors off the thermostat. Insulate the end of the wire you disconected with electrical tape. Now plug the cooler back in. If the compressor stays off the thermostat is the problem. Let me know if that helps. I know of a common replacement cold controll for that unit:)
Apr 05, 2009 | True Refrigeration Mega Top Sandwich Salad...
C17 RANCO THERMOSTAT WIRING
changing metnical Ranco Thermostat to Digital Ranco.
Apr 20, 2008 | Refrigerators
Kenmore Coldspot 106.7685110
There should be a shot circuit or near zero ohms across the two terminals when it is warm and open circuit when at freezer temps. Either the small capilary tube has leaked all of the nitrogen out or the contacts have rusted or corroded. I would say you have found the culprit....
Feb 16, 2008 | Hotpoint HSS25GFP Side by Side...
True Sandwich Unit - TSSU-27-12M-C Logo
461 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
