Question about Raypak 2100 Pool Heater Gas 336000 BTU' (Pilot Light) ()
Raypak 2100 temp sensor failure light is on
Heater will not light up. temp sensor failure light is lit up on circuit board (red light).
    Top Expert:
  • Raypak Master
  • 5,056 Answers
Replace temp sensor
Posted on Apr 27, 2016
  • 22 Answers
SOURCE: raypak 2100 digital heater give fault code eol
ILO or ROL. There is no EOL.
ROL is a switch inside the lower left corner of the heater. Press the red button. ILO is a lockout. Power down and power up.
Posted on Dec 21, 2008
  • 4 Answers
SOURCE: Replacing PC Board on Raypak 2100 Model 185 - connector differs
Sorry, I don't have an answer for you, but please let me know what happens.
I am in the process of buying the new board (# 010253F, right?) It hasn't arrived yet, but I'm assuming I'll be in the same situation. BTW, I am replacing mine only because the LCD screen is totally blank. Everything else about it is ok.
Please let me know what you did. My email is sroche@tellink.net
Thanks in advance,
_Steve
Posted on Jun 22, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
john224
  • 1378 Answers
SOURCE: last season raypak 2100 heater would light but
Thank you for posting your question here on Fixya.com.
Along the manifold there will be several gas ports feeding gas into the burner tray tubes. The tubes are the narrow steel tubes that extend under the heater from the gas line. We use a piece of #12 solid wire and run it in and out of the tubes from under the manifold. Spiders like nesting in the tubes and their silk blocks the gas flow. Once the gas migrates over from further away from the pilot you get the 'whoosh' of ignition. As you clean the tubes and recheck the heater be sure you pay attention to the flame color. Anywhere you see orange flames above a tube you need to shut down and then clean the tube. Orange flame means poor combustion and needs to be fixed to prevent sooting.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 10, 2010
  • 990 Answers
SOURCE: Can't light my Raypak Pool Heater.
Often you can see the pilot if you use a small mirror. With the button on the gas valve pushed down you should get pilot. Once the pilot is lit it warms the TC(thermocouple) creating the static charge to open the gas valve on it's own. The TC is set in the pilot assembly. It will be a small tube like piece with the wires coming from it. Some times you can pull and replace it but I will usually get the whole pilot assembly and just replace that. It will probally be rusted and can be cloging the tiny orface on the pilot itself.
If you have a milivolt meter you can check the TC by pulling the wires that come from it at the gas valve and with the button on the gas valve pushed in and a good flame you should get 500-700 MV from the TC. This is 1/2 a volt+ so you will need a MV meter. But this will tell if your TC is bad or if your valve is bad.
Good luck.
Posted on May 13, 2010
What is a high limit condition
temp sensor failure. when sensor read temps that are way too cold or way too hot
Apr 21, 2014 | Raypak 2100 Pool Heater Gas 266000 BTU'...
I have a RP 2100 Raypak Pool Heater Model number C-R185-EN installed about 1996 and used very little through out the years the front service light is on-- red --the back circuit board fault shows a sensor...
The part number for the thermistor for your heater is 005299B, officially called the temperature sensor IID it is also refered to a temp sensor or temp sensor kit.
John
Jul 09, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 Pool Heater  Gas 336000 BTU' (Pilot Light) () Logo
89 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
