Question about Keurig B30 Mini Coffee Maker
Is there a fuse inside the B31 mini plus keurig coffee maker?
I inadvertantly plugged the unit into a 230 volt instead of a 110 volt wall socket. The unit is of course not working. Can we replace the fuse if there's one inside the unit??
SOURCE: Need to no know how to take apart!!!!
I hope this reaches you, as I had the same problem. You start with the metal screws attaching the handle. The screws are strange, but you can use a small phillips... you need enough force to turn them, but don't break the plastic. Get the handle off, then look under the housing on top of the needlle... if you look in there, you will see 2 screws... then when housing is removed, you'll see 2 more screws... in other words - carefully keep turning screws until you have the part open that you want. I started with the screws near the needle that is the spout. just remember the steps, so you can reverse and close the thing up. Any problems, you can email me at: bdubois@maharam.com, and thank you for serving our country! If you need a new machine, maybe I can get you one. Barbara
Posted on Apr 17, 2008
SOURCE: Keurig problem.
Check to see if the gasket around the top "pointy thing" is damaged or missing. That just happened to mine.
Keurig will send you a replacement gasket free of charge. Just call them at 1-866-901-BREW (2739) with your model and serial numbers. The numbers are on the bottom of the machine.
Posted on Nov 21, 2008
cmccune04
  • 213 Answers
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 14, 2010
  • 58 Answers
SOURCE: Keurig Platinum B70 Coffee Maker stops working and
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
espressonist
  • 1711 Answers
SOURCE: How do I drain water
If leave it for a couple of months without using it, later on when you will need to use it again it by 95% it will be stuck. Their many parts related with water , 2 pumps, valves, jet pasages that even one of this goggled with a sales part then the machine will need complete desaesemble manual descaled and put back together.
So I sugest to find a way so that the machine keep work atleast once a week or even lent to a friend istead of put it on the shelf for long time.
Posted on Aug 20, 2010
My Keurig was accidentally plugged to a 220 v outlet instead of a 110. Need a repair shop located in the Philippines. . It won't operate anymore.
Chances are pretty good that you blew a fuse in the unit. I think it would be worth it for you to take it apart and check. If there is not a fuse you have lost nothing.
Nov 13, 2014 | Keurig Elite B40 Coffee Maker
Keurig B31 Mini Plus Brewing System not working
There is a transformer that take the 110 voltage and reduces it to 13.8 or 14 volts depending on your unit model, it runs an electronic board or little computer in the coffee maker. It's the brains of the coffee maker. I would say you fried the transformer and possibly the electronic board if the high voltage made it past the transformer. I have replaced the transformer in our sons Keurig and that fixed his problem but he didn't plug it into 220v. The transformer is not expensive, an eBay item at around $15 or so. Taking the unit apart is not an easy thing to do. But if your handy you could figure it out and test the transformer to see it it's putting out the right voltage. Just check the voltage tag of the one that it came with so you can order the right one for your pot.
Apr 21, 2014 | Keurig B31 Mini Plus Brewing System
How do you remove the needle of the Keurig
Don't...just clean the inside to keep deposits from collecting inside and stopping water from entering the tube.
Aug 14, 2013 | Keurig Mini B31 Plus Black Coffee Maker
Keurig mini plus b31 only half cup of the water dispenses
Reset the out-flow and dispensing format. See Manual for instructions.
Feb 16, 2013 | Keurig B31
Manual for Keurig B31
Call 1-866-901-2739 for a manual.
Aug 23, 2012 | Keurig B31 Mini Plus Brewing System
I have a new B31 mini plus keurig brewer and I put the water/coffee in, hit the brew button, it flashes red then turns off after about 2 minutes without brewing the coffee.
MODEL B31: I made the mistake of not running water thru the machine first (the Initial cleaning) and was unable to get water to come thru to the K-cup. Reservoir was hot and full and would not come out. SOLUTION: I took a bendy-straw and completely covered the inside needle coming from the top (that goes into the K-cup) and pushed it up with a fair amount of pressure and blew hard into the straw. Then sucked on the straw (BE CAREFUL IF THE WATER IS HOT) and water and some coffee grounds came out. The brewer worked perfectly after this!!
Nov 27, 2010 | Keurig B30 Mini Coffee Maker
Keurig B30 Mini Coffee Maker Logo
106 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
