Question about Radio Communications
I have a cobra cb radio cobra 25 it worked fine then it wouldnt transmit all anyone hearwas noise I think it is a rf transmits or somt help and tell me the number and location of the one i should replace
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
There could be more than one thing wrong . could be a BIG thing or a little thing .take it to a tech and let him fix it.
Posted on Oct 04, 2014
2 Suggested Answers
  • 1274 Answers
SOURCE: cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
Posted on May 29, 2010
Cant transmit on Cobra PR 4750 WX.
It sounds like you have a shorted RF output transistor.
Apr 22, 2015 | Cobra Radio Communications
S/rf is too high on transmit on my cobra 29 ltd bt
no matter what s/rf you are looking at it should not key much beyond an s-9 . vr 3 controls the meter. Key the mic and adjust it to s-9 then check you modulation.If you still think you need more then adjust vr 4 .
Jan 07, 2012 | Cobra 29 LTD CB Radio
Rf meter not moving when keying up
if the radio is transmitting fine, then the meter is shot. It happens. You can get them cheap on ebay. Its 2 wires and 2 screws. You need to un solder the old one and solder in the new one.
Oct 16, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 only transmit and recieve on ch 1
Hi, my name is John. Take the cover off the unit, and check for broken trace or loose solder joints around this area, ...hope this was helpful..Rate this solution on the four thumbs-up.....John
Jul 12, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Cb transmit noise
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
When i click the mic i get no transmit
If the receive works ok,sounds like a mic
problem,try another mic if you can find a
buddy who has a Cobra that may let you
try it most all Cobra mic will work but not all.
Good Luck
Sep 08, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 and all it will do is light up. It will not receive nor will it transmit. What might be the problem?
the easiest thing to check first is the mic..........if the mic is broken cobras wont receive or transmit
hope this helps.......good luck!
Dec 05, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 200gtl High Power Transmit problem??
Depending on the type of power supply, radio frequency (RF) energy from the transmitter may be 'fooling" it into thinking that you're overloading it. Check to see if there's any discernible dimming of the meter lamp when this problem occurs, if so, the supply is the culprit.
Otherwise, its probable that the final amplifier transistors are overheating, either they are 'leaky' or not properly attached to the heat sink.
Jun 23, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
