Question about Brute 020426 2400 Psi 2.0 Gpm 190cc Gas Power Pressure Washer
No water sprays out
Water will not go into the pressure hose to spray out
I have a Milwaukee paint sprayer that will not prime and stay primed. If I work with it I can get it to spray water sometimes and never paint. I tried to prime with it and had to water down the primer to...
I had the same problem. Turned out to be the hose clamp was loose and it was sucking air. I did not find the problem until I connected the garden hose adapter and pressurized the line. After the line was pressurize water was sqirting out at the from the hose connection on the right angle connected. Tighted the clamp and it primed without issue.
Sep 17, 2012 | Air Tools & Compressors
Coleman 2400 PSI Pressure Washer - WATER LEAKS OUT = ?!? Help me please!!! ((-:
Usually, there are spaces between the pump and head portion of the pump. This space is not sealed and will allow water leaking past the seals to come out. There may be a seal kit available, however I have had better luck just changing out the whole pump. There are many available on ebay. Search for one that will use same mount and hoses. Once the seals are gone, the pump will never be the same (may nickle and dime you the death).
Oct 30, 2011 | Garden
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
Starts ok wrench appears heats ok wash cycle pressure strong at first then fades wrench appears -p2 -cleaned screens and checked spray arms .incoming water pressure 20 psi whats wrong ?
Check the spray arm. Machine water pump. After this pump pressure
builds up to the spray arm. Rubber hosejunction inside the wash tub.
This place gets connected to the spray arm system.
You can see this when you draw the tray for loading vessels.
Slowly push it and watch the junction where this gets locked into the
rubber hose mouth inside the wash tub. There should not be any
water pressure leak.
Sep 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
Low pressure when spraying, inlet water is good.
try taking off water hose an in that water in let spray wd 40 while it is running thats the best advice i can give you do it for like 2 minutes
Aug 31, 2010 | Honda Pressure Washer PSI 3000
No pressurized water spray
internal pump failure....check that it is not blocked ...the water supply hose only fills tank then the pump pust pressurised water to the spinning arms.
Jul 20, 2010 | Hotpoint 24 in. HDA900X Built-in...
Top level rack pots are not cleaned, spray head does not rotate but water coming out of sprayhead, no obstruting parts
Check and see whether it freely rotates, when turned manually. The spray arm rotates under water pressure from the pump inside the machine.
Check inlet water pressure and clean the strainer at the inlet hose end near th inlet to the machine. Check and clean the spray arm axle housing also
Apr 12, 2010 | Dishwashers
Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
Mar 17, 2009 | Briggs & Stratton Pressure Washer...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Brute 020426 2400 Psi 2.0 Gpm 190cc Gas Power Pressure Washer Logo
32 people viewed this question
Top Brute Garden Experts
Vernon Taylor
Jesse Walters
Jesse Walters
Andrew Taylor
Andrew Taylor
Are you a Brute Garden Expert? Answer questions, earn points and help others
