Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Error code E-01 F-03 What does that meen?
The dryer runs for 2 minutes then beeps and flashes E-01, F-03 error codes. What does this keen?
fixinit4me
  • 10 Answers
SOURCE: Maytag Neptune dryer error
To find out what the code means,
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Posted on Oct 28, 2007
reg501
  • 413 Answers
SOURCE: Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
Posted on Jun 01, 2008
buffalonyman
  • 1865 Answers
SOURCE: error code F22 after 1 minute of drying
If it is new, you should call maytag to repair under warranty terms. The unit could be defective.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Posted on Nov 12, 2009
  • 53 Answers
SOURCE: dryer has a t5 error code and won't start.
There should be two or three screws at the back holding the top on. Take these out and slide the top back and off. Inside should be a service tech sheet that will tell you what the code means and what to replace or check. Once the top is removed it shouldnt be hard to see how it is disassembled.
Posted on Jul 08, 2010
  • 67 Answers
SOURCE: Power Failure without tripping breaker
Sounds like an overheat code tripped due to obstruction in the exhaust. There is also a vent tube on the bottom of the dryer that could be loose.
Posted on Jul 27, 2010
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
HOW do I get rid of a code on my dryer or is it EL8,what part repairs this code.
Good Afternoon Butchie111, thank you for your post!
From the information you have provided your Frigidaire dryer is displaying an error code of "EL8" and it will run for 30 seconds then beep the code. I am showing that "EL8" is an invalid code. It could be a possible miscommunication error so I would suggest performing a reset on your dryer and you can do that by disconnecting power from your dryer for roughly ten minutes. If that does not help your issue could you please provide me with the new error code or inform me if your dryer still displays "EL8"? I look forward to your response. -Matt
Feb 22, 2015 | Frigidaire Dryers
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Frigidaire Gallery model GLEQ2170KSO dryer turns off within a minute.
Hello allisonarena - Try reprogramming the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn on the unit. If issue persists, then the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. I would recommend connecting with an experienced appliance repair tech to assist further and to reduce the risk of unnecessary parts.
Jun 12, 2013 | Frigidaire Dryers
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
I get a flashing E-1 error code
I keep getting the flashing E-1 error code...
In the manuel for trouble shoot I do what it ask and there's no change. It will run for 2 or 3 minutes then just start flashing " E - 1" code. Need help Please.
Jun 08, 2010 | Whirlpool GEW9200L Electric Dryer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    GLEQ2152ES the error "PF"
    My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
    May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
    Kenmore dryer HE2
    my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
    May 05, 2008 | Kenmore 85871 Electric Dryer
    3 beeps mean what
    If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
    Oct 17, 2007 | Kenmore 62062 Electric Dryer
    Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
    342 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
