Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba splash screen freeze
Toshiba sat pro a100 powers up to the splash screen at the bottom of the screen it says press f2 or f12 but it will not let you do anything the progress bar reads about 70% but will not move any advise will be greatfully recieved many thanks nobbzee
  • 107 Answers
Sounds like a bad hard drive to me. I would suggest testing the hard drive using a bootable testing program like pc check and if it is bad replace the hard drive and restore the operating system
Posted on Jun 26, 2009
How to set up bios on toshiba laptop tecra m1
Hold down the Esc key and press and hold the power button until the on/off light on the system indicator panel illuminates (green) for approximately one second. When the following message appears on the screen: "Check system, Then press [F1] key," press F1. The System Setup screen appears.
If that doesn't work, try powering on the laptop and when the Toshiba splash screen comes up, hit F2 or F12.
One of these methods will get you in to the BIOS setup.
Mar 10, 2015 | Toshiba Computers & Internet
How to get to toshiba nb205 bios
Jun 10, 2014 | Toshiba NB205-N210 Netbook
Not shown booting options
f8 or f9 shows the booting option
Aug 08, 2013 | Toshiba Satellite A15-S127 Notebook
Toshiba satellite L300 freez...
Hi the problem sound familier, Firstly unplug all the USB devices from the notebook and remove the battery and the power cable and press and hold the power button for 10 sec and then remove the memory from the notebook one by one if there is more then one and reset it agian and try to connect the notebook on power cord and check. let me know about it.
Feb 13, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Nov 27, 2009 | Toshiba Satellite M35X-S114 Notebook
Splash screen comes up with f2 to enter setup f12 for boot options but freezes will not proceed no farther
First of all if it will let you press F2 and see if you can reset the BIOS to default configurations. Hit F10, save the changes and exit the BIOS.
The computer will restart and hopefully boot to the operating system boot screen.
If it's still freezing on post then remove the battery and the AC power supply. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
Good luck.
Sep 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Dell Dimension freezes at startup
Try disconnecting the data cable from the hard drive, then see if you can boot to the Resource CD. If you can, there is a good possibility the Hard Drive is bad.
If no difference, then try disconnecting everything but video, see if the system will boot past the Splash screen. SOmetimes periferal items cause issues
Mar 29, 2009 | Computers & Internet
Operating system not found
insert system disks and re-install everything again.
Mar 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
Dec 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
201 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
