Question about Campbell Hausfeld Air Tools & Compressors
28 degree framing nailer will not cycle - Campbell Hausfeld Air Tools & Compressors
3 Suggested Answers
  • 1383 Answers
SOURCE: Need a gasket for the
Parts are generally not available for these guns, however you can make a much better gasket (factory gasket was made out of plastic and fails) using material from auto parts store (do not use cork, but paper type). They may not have the right thickness, but using two layers works just fine. Take two layers of gasket material larger than needed (say 6 inch square )and staple them together around edges cut hole in center larger than cylinder and mark exactly where bolts pass thru and vent hole. I use leather punch to punch holes (but any punch will do). Place gasket on body of gun and bolt down head for air pressure test. If test ok you can trim excess gasket with exacto knife without removing head or mark gasket remove head and trim. I usually do not trim too closely as origional gasket on the inside. No need to use gasket sealer. You can even make a temp gasket using cerial box. About three layers of cerial box will work untill moisture enters gun, then over time the cardboard will get soft. Good luck
Posted on Mar 16, 2011
  • 885 Answers
SOURCE: Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Posted on Mar 04, 2013
What do I need to replace in my bostitch 28 degree framing nailer?? I shot I one time and now there's air leaking from the trigger area!!
More than likely you need a TVA6 valve it is about a 10minute fix. trigger valve will cost about 20$ on eBay or Amazon
Mar 22, 2015 | Air Tools & Compressors
What is the difference with different angle framing nailer
20 degree are plastic correlated and 28 degree(Bostitch) is wire correlated and 32 degree angle nails are paper tape correlated and lastly coil framing nailers are 15 degrees.
Oct 05, 2014 | Tools & Hardware - Others
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
I have a Bostich f28ww. It wont fire. When you pull the trigger, it only lets out air
The seals have gone bad you will have to replace the seals in it. Try tightening the nuts on top of it
Mar 02, 2011 | Stanley Proto Stanley Bostitch F28WW 28...
Wiil a 22 degree Paorter Cable FR350A Round Head
No... it will fire 21-degree nails and perhaps 23-degree nails (but sont think they exist) and it is a full-head framing nailer so it is designed for firing round head nails. Using clipped nails will likely jam the nailer as these nails are stripped closer together with overlapping heads in the nail strip and the FR350A has a full round driver so you will run into issues with clipped nails. If you are having problems finding full round head nails, you can find them on Amazon to fit this nailer. Otherwise any good tool or trade tool store that sells nailers will likely have a suitable nail supply available for the FR350A.
Feb 09, 2010 | Porter Cable Air Tools & Compressors
F28 ww framinf nailers. 4 relatively new
It sounds like you are using the wring nails. check the recommended nails and the degree of the strips. there is a large variety of degree's available if it is a Bostitch usually 28* is what your looking for. next the gauge of nails need to match and then whether or not they are paper collated or wire. that will cause problems like that all day. hope this helps
Dec 28, 2009 | Stanley Bostitch F21PL Nailer
What is my framing nailer?
I would go to Campbellhausfeld.com and under products look at the couple nailers they list. They do have a 28deg nailer and also a 21deg, so you could be right in thinking that it is a 28deg, they also show how to find the model number if there is still a tag on the tool. This would be a start to identify your gun
Sep 25, 2009 | Campbell Hausfeld Tools & Hardware -...
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Air Tools & Compressors Logo
37 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
