Question about Odyssey Health & Beauty
Batteries went dead during transportation. put charger on, it wont charge. turn key on when charger is pluged in, and every thing works. whats wrong?
Some how batteries went dead during transportation .they wont charge back. but when charger is plugged in, and I turn key on, every thing works fine. whats wrong?
SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Posted on Jan 16, 2008
SOURCE: Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Posted on Jun 26, 2008
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Posted on Oct 01, 2008
  • 118 Answers
SOURCE: Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
Posted on Nov 27, 2008
  • 118 Answers
SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Mar 26, 2014 | Polaroid S7 7-in. Internet Tablet
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
My Ipod 3rd gen. wont work other than when its pluged into the pc
Your battery is most likely dead to the point where it can no longer hold a charge, which is the reason that when you unplug it from the computer, it dies instanly. Batteries are pretty cheap going up to about as high as $25 and if you get it done at a ipod place, installation should not be that much.
Aug 05, 2009 | Apple iPod nano 8 GB Pink (3rd Generation)...
My motoflip is not charging
Your battery is dead. You need to change it. One more thing you can check before changing your battery put your battery in some other handset and try to charge it through that charger if it works then your chargers output voltage is wrong change it.
Jun 16, 2009 | Cell Phones
Apr 09, 2008 | Computers & Internet
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
Charging problem
check the base connection this can be damaged if the charger is inserted the wrong way.
If this has happened then you will need a tech to repair it.
If it is not this then I think your battery has died
Nov 16, 2007 | Samsung SGH-E370 Cellular Phone
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Health & Beauty Logo
27 people viewed this question
Top Odyssey Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Odyssey Health and Beauty Expert? Answer questions, earn points and help others
