I cant see anything on my tv unless i hook up a dvd player or my xbox..i only get a static picture when i connect my cable..or an antenna
  • 40 Answers
Check your input selector on tv and see if it is on channel 3 or 4
Posted on Jun 19, 2009
Not hooking up a computer, just dvd recorder, no other hook up ports on tv, just cable jack, dvr will not come in on any ststion
Does the DVD player have an RF out if it does then put antenna cable on RF in connection port on DVD recorder and purchase another antenna cable to go between DVD RF out to TV antenna in.
Then manually tune a TV channel to the channel frequency that the DVD outputs on.
Aug 24, 2014 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Great picture but really loud static when watching dvd
Hook the DVD to another TV set, this will prove if the player is the issue or original TV
Mar 19, 2012 | Yahoo Diamond Vision DVDC803-04 DVD Player
Static jumping picture
sounds like bad connection or bad tuner in the tv - have you tried playing a DVD or VCR tape ( if available ) - more info would be needed to help you further -such as - are you on cable, cable box, satelite or antenna and do you hook up to your TV using the a/v or RF(cable) input.
Oct 18, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Need to hook up to tv
use the colored lead (RC) cables to connect from dvd player to your tv, it is color coded so you cant go wrong, then select av on the tv to watch dvd, if it can connect to tv with rc cable then you will need an adapter to connect dvd through antenna jack ok
Jun 29, 2009 | Protron PD-007 DVD Player
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Jan 02, 2007 | Samsung TXJ2754 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
