Question about Kenmore Ovens
Bulb replacement model number 43789
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Replace light bulb
Hello tony sunlitis - I understand that you would like to know how to replace the light bulbs in your unit. So I can assist you better in pinpointing you the information, may you please provide me the model number.
Nov 26, 2012 | Frigidaire 27 in. Electric Double...
Replacing oven bulb
what type of oven isthis and model , can you get to the bulb, is it broken inside the socket ?
Dec 06, 2011 | Ovens
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Sep 17, 2011 | GE Profile JTP18 Electric Single Oven
The clock light and timer light on my GE XL 44 stove has dimmed and cannot be seen. How do I get to the bulb to replace it?
I looked up your model number and had trouble finding the correct bulb. From what I can tell though, this is the one you need. BULB
If you need more help let me know I would be happy to assist you!
http://www.pricedrightparts.com/products/10-Watt-Appliance-Bulb-10C7DC.html
Jun 11, 2011 | Ovens
I need some help please, The bulb has gone in my oven! how do I change this and where would I get a bulb? The oven is a candy and the model number is FPP403.
Most ovens use appliance bulbs that can be purchased at any home improvement store. Open oven and locate the glass protective cover and remove it. Remove bulb and replace w/new one, place protective cover back.
Apr 23, 2011 | Candy F248P Electric Single Oven
Replace oven light bulb? magic chef wall oven
for model 9815xub, the oven light consists of a light bulb cover(clear plastic, sometimes called lens) the light bulb receptacle( pressure mounted against the back wall of the oven ) and the light bulb, standard appliance bulb that screws into the receptacle, the same as the lens, it also screws into the receptacle, twist counter clockwise to remove both the lens and the bulb. as a reference try the following site:
www.partselect.com/ and type your model number in the window, then click on the oven cavity breakdown to view thwe assembly.
Jan 31, 2010 | Whirlpool RBS275PD Electric Single Oven
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Need part number for oven bulb
looked up the bulb part is no longer available, but it looked like a regular appliance light bulb, remove the old one no diffrent then any appliance bulb you can buy in the supermarket if need be
Feb 19, 2008 | Ovens
Ovens Logo
12 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
