Question about Technics SL-PG480A CD Player
Technics cd player sl-p220. Connection ok, displays and connects with cd showing number of tracks but does not play disc
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
HOEEEE
  • 7 Answers
SOURCE: Technics SL-HD350 Cd Player - Sound problems
This maybe due to overheating of some Sort.
Try taking it out of where it is where theres a good flow of air.
Then try running a cd.
Try Putting in a Cleaning cd, this maybe a fault with the laser.
Regards
Posted on Jan 05, 2008
SOURCE: Technics SL-MC6 CD player
a) the current CD in use is in slot 23
b) behind slot 23 is a CD left inside
Posted on Jul 31, 2008
jomabug76
  • 1148 Answers
SOURCE: Technics SL-PG440 CD player no audio output
GET NEW RCA JACKS
Posted on May 15, 2009
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
My cd player technics sl-p220 no spining the cd
More than likely the belt has failed or one of the loading mechanisms many plastic parts. The only thing to do id replace it, parts are not sold.
Oct 07, 2016 | Technics Audio Players & Recorders
I have a technics SL-CH505 compact disc but it will not play burnt CD;s any suggestions my other technics SL PG 400A plays them noproblem
The Optical Pickup(laser) may be weak. It takes much more power to record than play, which I guess it works.
Oct 13, 2014 | Technics Audio Players & Recorders
I have a Technics CD changer SL-PD867 it will not play re writable disc's all other disc ok
You should realize that this player is about 20 years old.
It was not designed to read CD-R or CD-RW media.
The signal from these media types is different from audio CDs you buy.
May 11, 2014 | Technics SL-DZ1200 CD Player
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
Technics SL-DZ1200 NO CD AUDIO TRACK
Lazer is shot, Not reading info from the disc anymore,
Nov 28, 2012 | Technics SL-DZ1200 CD Player
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
My Technics SL-DZ1200 will not play certain MP3 tracks. It will play some, but on others the message "track error" appears. these same disks will play just fine on the other cd player machines I have...
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Jun 08, 2009 | Technics SL-DZ1200 CD Player
CD's come out distorted on the TECHNICS SL PG 580A
TRY NEW RCA JACKS AND TRY BLOWING IT OUT,,GET YOU A LASER LENS CLEANER
Feb 26, 2009 | Technics SL-PG480A CD Player
Technics SL-PG480A CD Player Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
