Question about Tomtom ONE 3RD EDITION GPS Receiver
Tom tom switches on, Tom Tom on display but noting els hapins
  • 32 Answers
Try making a back up using tomtom home, also create a directory on your computer and save the contents of your tomtom there, i had this problem which turned out to be corrupt firmware/ application, which after i formated and reloaded the f/w/app from tomtom.com it worked fine....be sure to back up before you format,
then you can relaod your maps
si
Posted on Jul 04, 2009
Factory reset gps
UNFREEZE Tom tom sat nav USING WINDOWS OR MAC PC
This will unfreeze your tom tom after exhausting every avenue this works!
You will need Internet access.
Ensure you have the correct tom tom desktop softwear installed on your computer for your tom tom device.
If not then download from tomtom
Removed sim card from tom tom located under sticker lower end of tom tom.
Carried out on a windows laptop with windows 7
(Note this should also work on mac although I did not get to try it and it is stated you will need rosetta on intel macs)
Ensure you download the flash tool for tomtom (clear_flash.dmg) for your operating system windows or for the mac VERY IMPORTANT YOU HAVE THE TOOL DOWNLOADED FIRST.
1.For windows: www.tomtom.com/updates/clear_flash/clear_flash.exe
connect tom tom to computer
find the tom tom on your computer and select all the files
you can firstly copy these to another location or separate drive before deleting all files.
Now delete ALL the tom tom files
Format your tom tom to FAT32 if using windows (im not sure of the mac settings yet)
Keep your tom tom connected to your computer
Run the flash tool and Flash the tom tom memory with the tool.
Restart your tom tom
It will update (but this time it should work!)
Select done after update
Tomtom reboots (restarts)
It may ask you to install a new update but there may not be any update to install just
Select yes to update.
Eject tom tom from your pc by selectinglower right corner symbol.
Now unplug device if ejected correctly
Congratulations your device should now work again.
Note I did not replace my sim card as it is not required to work the gps.
Hope this helped someone.
My device does not keep its settings What should do
Aug 14, 2014 | Tomtom TOM TOM ONE WE V3 GPS Receiver
ALGUNOS CAMINOS SON DIFERENTES QUISIERA ACTUALISAR EL MAPA
que clase de GPS es si es Tom Tom . tienes el cd que vino con el gps por medio de la computadora tu puedes actualisarlo oh en la internet vete ah la marca de tu gps y baja el programa normalment la companias tiene esto disponible
Jan 16, 2011 | GPS
Deseo cargar mapa de Uruguay en tom tom one, como
amigo , yo tenia el mismo problema de mapas con un gps de un tomtom y otro con sistema wince ,luego busque y me recomendaron un servicio tecnico en cap fed argentina y me cargaron argentina y uruguay,ya me lo solucionaron,ahora quedo barbaro !! te paso la pagina ,espero que te sirva ,salu2 http://www.mapeo-gps.com.ar/
Jan 09, 2010 | Tomtom ONE GPS Receiver
I need help on changing to the us My tom tom is on a different country
You will need to Purchase and load required US MAP(s) via 'TOM TOM HOME'.
When the new MAPs are registred to your device, you can then use the 'Change preference' -> manage Maps -> Switch Map -> then select the appropriate 'registred' US MAP.
Please note: always backup your GPS via 'Tom Tom Home' backup utilities first!
If you have limited storage, you may need to delete your existing map(s), that were previously back-up, before loading the US Maps
Dec 25, 2009 | Tomtom ONE GPS Receiver
My tom tom has gone blank without warning.
Try these 3 things - wait at least 20 seconds before trying the next step:
* Reset the device, you may need to use a paper clip to do this, then try the power switch.
* Remove the SD card and re-insert it, then try the power switch
* Hold down the power button for about 5 seconds.
Jul 31, 2009 | Tomtom GPS
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Tom Tom 910 Green light but does not come on.
Remove battery and disconnect from power for 5 minutes, also remove map card, this will reset the device. Try it out
click;
Repair4GPS: How to Clean, Upgrade, Repair, Mod, Disassemble a GPS ...
see here
http://www.tomtom.com/lib/doc/legal/lw/LW-English-US%20CAN.pdf
To only way you can fix it is taking apart the Tom Tom, checking if the flat ribbon cable and connector to the screen are well in place and eventually replace the display ($80 on Ebay).
Unfortunately this will invalidate the guaranty, and you risk to damage your GPS if you are not a really experienced DIYer. Tom Tom offer one year full guaranty on all their receivers.
Contact Tom Tom and get it repaired:
Support URL: http://www.tomtom.com
Support Phone Number: 978.287.9555
Support Email Address: usainfo@tomtom.com
Hope this may help;
DON'T FORGET TO RATE:
Aug 28, 2008 | Tomtom GO 910 GPS Receiver
Tomtom ONE 3RD EDITION GPS Receiver Logo
751 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
