Question about Tools & Hardware - Others
How do get the bearing off the front of my dremel multipro
    Sergeant:
  • 231 Answers
2 Suggested Answers
  • 3 Answers
SOURCE: worn front bearing on Dremel Multipro
Sorry, here is a link to that picture, full sized.
Grease Monkey 626
Posted on Aug 24, 2009
Dremel multipro variable speed only starts in 4 or 5 speed
with tool unplugged rotate tool end with your finger tips if it gives any resistance to this your bearings have forign material in them (happens if your doing grinding allot) if a liberal dose of light oil (sewing machine) does not improve this friction im sorry but you;ll have to replace tool to run slower speeds
Aug 17, 2014 | Dremel Variable - Speed Multipro Rotary...
Need to replace DE bearing dremel model 398
go to Http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/Attachments.aspx
Mar 16, 2013 | Dremel 395 Variable Speed Multipro Rotary...
How do I attach tools to my Dremel?
hello. You loosen the arbor at the base of the shaft closest to the tool. There is a tiny wrench in the kit that came with the dremel, or you can use a pair of pliers to loosen it. Joe
Apr 17, 2010 | Dremel Variable - Speed Multipro Rotary...
How do i take the bit off of a dremel multipro model395 type 5
unscrew the collet nut, and then if it's still stuck, tap the end of the bit on the table or something solid. It'll come loose then.
Mar 16, 2010 | Dremel Variable - Speed Multipro Rotary...
Flex shaft attachment
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
Mar 02, 2010 | Dremel 225 Multipro Flex - Shaft...
Should I be lubricating my dremel (395) tool?
Just a comment-Based on experience, I would go with BOTH their suggestions and order brushes and bearings. That squeal is definitely the bearing; it is a sleeve bearing; RPMs too high for a ball bearing to last and the sleeve bearing has a solid lubricant cast into it.
Dec 16, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Worn front bearing on Dremel Multipro
You can put new grease into that bearing without removing it by following the steps in this M.S. Paint drawing I made. After a bit of protest, mine started running a lot better.
Dec 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
27 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
