Question about Boating
Outboard fuel mixture is it 25.1or50.1 in my 18hp tohatsu
4 Suggested Answers
  • 10 Answers
SOURCE: fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Posted on Oct 25, 2009
Testimonial: "Thank you coachtheune. I appreciate your help."
  • 51092 Answers
SOURCE: fuel mixture for an Evinrude 1963 5 1/2 Fisherman
50 to 1
Posted on Apr 25, 2010
SOURCE: i need a free workshop manual for tohatsu outboard
how can i get service manual for a tohatus m40c 1992?
Posted on Apr 14, 2011
Tohatsu 30hp M30 outboard.
Sound like problem with ignition or fuel delivery system
Feb 22, 2018 | Boating
I am wondering if I can retrofit an electric tilt to my Tohatsu 9.8 4 Stroke outboard.
very possibly can
if there are 2 small shockys in the mount , the rams will fit in their place and the rest is academic as to fitting
You should be talking to a Tohatsu service dealer as they have all of the ideas as to the fitment procedures
Feb 14, 2018 | Boating
I have a 1995 25 horse tohatsu outboard and would like to us a fuel additive cleaner what do you think
a quality injector will be ok
to avoid problems do not use any e-mix fuels as the ethanol content attracts moisture that gives you fuel and injector problems
Jul 11, 2017 | Cars & Trucks
Misfire on Tohatsu outbaord.
one would assume so but as you have not mention if it is a 2 stroke or 4 stroke , that assumption would possibly be wrong
2 strokes use reed valves between the carby and manifold and the crankcase and in outboards these reed valves can split and not function properly especially at higher prms
these reed valves allow fuel mixture in when the piston goes up and shut off when the piston comes down creating a pressure in the crankcase which pushes the mixture up the bypass of the cylinder into the combustion chamber
if these reed valves are not working properly or the crankshaft seal are failed this compression in the sump doesn't occur properly and engine running problems result
IF it is a 4 stroke the soaking the carby in cleaning fluid will only remove 1/2 the problems
It is best to have the carby fully overhauled by an accredited outboard mechanic as there will still be corrosion in the body and mixture passages that cleaning fluid alone will not remove.
have the ignition system checked as it may be an overheating component ( coil --ignition module) that is causing the failure.
Aug 11, 2015 | Boating
Why my 2006 tohatsu 5 h.p outboard will not idle down to trolling speed without spitting sputtering then dieing.
Remove the carburetor and thoroughly clean all of passages by compressed air you probably have blocked passage for fuel on the low idle side
Nov 09, 2014 | Seloc Mercury Outboard Engine Repair...
What year is Tohatsu M15B2 serial number 351A33838 outboard
Hi!
You can contact Tohatsu directly using the form provided at the link below.
Hope this helps,
-Steve
http://www.tohatsu.com/contact/wiz_modelyear.html
Aug 06, 2014 | Raymarine St6002 Smartpilot Hydraulic...
Have new tohatsu outboard that runs fine but wont rev out over 4500 rpm
I just looked at 7 different sites and they are saying Max RPM is between 4,500 - 5,050... How accurate is your Gauge?
Prop Pitch will greatly effect MAX RPM.
Apr 05, 2013 | Sierra International 18-6431 Marine...
My tohatsu 35N is missfiring when idieling other wise runs grate plugs are new thanks
Ensure you run the recomended fuel mix.100 to 1is what most modern engins run on. Read the manufactures instructions, sometimes on the cowl.
Cheers, Timo
Apr 21, 2010 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
32 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
