How to switch channel to dvd on hitachi tv - Televison & Video
2 Suggested Answers
  • 1335 Answers
SOURCE: Hitachi DV-PF 2U dvd player works fine when hooked
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Posted on Dec 30, 2010
I've got a Hitachi 19 inch tv/dvd combo L19DP04U. It has 2 issues. Firstly, when you manually select a channel from the remote control, it always defaults to channel 01. Secondly, when you turn off the...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Sep 06, 2017 | Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
Everything is plugged in, the disc is in and the wii is on, on the other television, it used to come on autmatically but on my hitachi television, it doesn't come on automatically, i have pressed many...
Mine too, we need to find the AV channel. All our friends who have a Wii have had no problems, just plug it in and switch your remote from TV to AV and it's there. My Hitachi remote does not have a TV/AV button, and the other options, S.Video, Composite Video, Component etc is taken up with other things eg Foxtel, DVD player and DTT tv channels .... HELP!!!!
Jan 02, 2011 | Video Game Consoles & Games
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
Dec 30, 2010 | Hitachi DVD / VCR Combo
What channel do i put the tv on in order to watch
it really depends on which input you plugged it into, if you plugged into the cable connection make sure on the dvd player it says output for that connection, if it says input then you can't use it as an output, a lot of the new ones are made that way. use the rca outputs and plug it into the input on your tv, then switch the input from your remote and you should see it pop up, should say input 1, input 2, frnt, and others, those are actually channels
Jul 04, 2010 | Hitachi Televison & Video
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
The channels won't store on my hitachi L19HP03U TV
ohh..your memory ic corrupted change it but it need to program use memory ic copier to copy the ic first ok
Jun 05, 2009 | Hitachi 32CX39B 32" TV
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hitachi C28W440N can't switch over AV channels no remote
have you tried buying a universal remote? you can get a decent one for £10 these days from any electrical store, such as curry's or maplins. it gives you a 3 digit code for the tv to link up with the remote and then you can switch over to av. some hitachi tv's also link up to av automatically if you connect your game station via scart socket (in the back of the tv) if you turn the tv off and link your wii up to the back and make sure the power is turned on before the tv is switched on, there's a chance the tv will auto detect the av channel. not all do but it's worth a try. hope this helps!
Dec 25, 2008 | Symphonic ST419E TV
Hitachi 27
If the sat feed is on channel 3, and the TV is tuned in and still does not get the feed, check the feed wire to be okay. If all is okay, there is a possiblity that the tuner module in the set has failed.
Jerry G.
Apr 29, 2008 | Hitachi 27CX01B 27" TV
Hitachi 42PD8700 U
switch on the dvd player so it's playing, then do a new master tune. press the dtt/tv button so you are watching the internal freeview system, then press menu, then go to installation, and re-install all channels. the tv will then detect your dvd player in the intial set up/tune mode.
hope this helps..
Oct 17, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
