Question about Pride Victory 4 Wheel Mid-Size Electric Scooter
Colt pride delux does handle at back which dismantles scooter cause batteries not to sit right for charging if asnt been put down properly
  • 118 Answers
SOURCE: Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
Posted on Nov 27, 2008
  • 118 Answers
SOURCE: Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
SOURCE: Need a wiring diagram for Pride Rally Electric Scooter
I can tell you how i fixed it for $19.95
Posted on Jun 22, 2009
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
gewiz
  • 1263 Answers
SOURCE: I have a Pride Legnd..the scooter started loseing
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Posted on Dec 15, 2009
Testimonial: "Any insight to a problem is a positive step."
Pride colt plus mobility scooter light flashes 7 times battery fully charged frewheel lever in correct position and there is an audible continueous horn type noise but the scooter will not move
hi , 7 flashes mean the there is a issue with wigwag also known as the throttle lever now can you confirm the year of the colt please ?
Regards
Rob
Feb 08, 2016 | Pride Health & Beauty
Pride colt plus mobility scooter. I need to replace the key switch ie. Single pole, double pole, the switch I got is jd a series. Please help
Either go to a pride dealer and get the proper job switch or look on eBay or Maplin for a similar. Check current rating of switch. Make sure you disconnect the batteries before attempting this job.
May 31, 2015 | Pride Health & Beauty
Charger showing full batteries not
No, you almost for sure have screw down terminals on your battery, not a fitted battery. The charger will read full when the charger has filled it as high as it can or has fully cycled. With a full charge take your batteries to an auto store or mechanic and have them tested.
Apr 20, 2014 | Pride Health & Beauty
Low battery indicator
look for corrosion on the battery terminals. Make sure they are clean and tight. The charger cannot overcome severely discharged batteries. Seperate the two batteries and use a 12 automotive battery charger to bring up the charge. Then reconnect the batteries and use the 24 volt charger to top off the charge.
Feb 14, 2014 | Pride Health & Beauty
Scooter stops after about 3 mile as if battery dead
hi, okay now does this happening every time ? or is the distance variable ?
check the batteries are fully charged, if possible check the batteries with a electrical meter when it stops again , insert the probes in the charger socket the outside ones , the middle on you can ignore , check the voltage , below 23 or 24 volts this means that once you start going again the voltage will drop causing the controller to cut out , they normally cut out at about 18 volts .
Satisfied that's okay now the brake could be breaking down ? do you hear it click when going along ?
At worse your controller could be breaking down
Regards
Jan 15, 2013 | Pride Mobility Products Pride Mobility...
Pride Pursuit XL scooter won't charge
Is this the Pride Colt XL 8 scooter ? if so look at the steering column, there is a fuse here for the charger ?
Please give feedback.
Dec 19, 2012 | Pride Mobility Pride Pursuit XL 4 Wheel...
I have the Shoprider Delux scooter.I brought it second hand.I put in a new battery but its not holding the charge. I seem to have to charge it up before any trips out.When its fully charged and I go about...
Yvonne,
When you say that you put in a new battery, I hope you mean new batteries. This particular scooter takes 2 batteries and just changing one will leave the remaining one in poor condition. Make sure that you have replaced the batteries with the correct size and type. This scooter takes 2, 40 amp hour batteries. Sealed gel AGM batteries are preferred. The batteries should have the number 40 on them with a date code. You need new, fresh batteries to have them work properly. A date code tag of A1 indicates the A month(1st month) or January of 2011 (1 is for 2011). If you are not sure of the battery condition a local shop can load test them for you.
There is a possibility with a 5 year old scooter that a worn motor/brake will cause excessive current draw and drain your batteries. A qualified technician can determine this for you with a service call.
Hope this helps.
Mar 18, 2011 | Shoprider Sprinter XL4 Deluxe 4 Wheel...
Could i buy an instrution manual for a pride colt delux mobility scooter.
keith go to the following link and they have an owners manual avaliable for download http://www.pride-mobility.co.uk/product.aspx?id=18&range=4#supportToggle Hope this helps you
Sep 30, 2010 | Health & Beauty
New battaeries willnot hold charge
Sounds like you have a bad charger. If you have access to a volt meter you can set it to volts DC put the meter to the batteries then plug in the charger. If the volts go up on the meter after you plug in the charger is working ok.
Jan 13, 2009 | Pride Mobility Products Pride Mobility...
Battery power on mobility scooter
Most scooters show a drop on the battery level meter when in use, as long as it is`nt slowing down it should`nt be a prob. I mean,when you engage the throttle you ARE putting a load on the batteries,so it`s only par for the course that the indicator would drop a bit.
Jan 04, 2009 | Pride Mobility Products Pride Mobility...
Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
