Question about Delta TP300 Shopmaster 12-Inch Portable Planer
I need the plastic hands - Delta TP300 Shopmaster 12-Inch Portable Planer
Water steaming from back of elantra motor 2000. when I put my hand down the back it feels like a plastic area broken. what would this be.
One of the coolant hoses or plastic coolant pipe is leaking coolant. You need it repaired and refilled with coolant.
Jan 30, 2015 | Cars & Trucks
Where is the fuses on a 1983 ford fairmount?
they are under the steering wheel behind plastic cover RH side you will need a flat head S.driver pull and turn 4 plastic screws hand brake will need to be out
Jun 15, 2012 | 1983 Ford Fairmont
I need to replace the expansion tank but I cannot figure out how to remove the plastic hose assembly on the bottom of the tank. Any ideas?
not sure completely as models do change but i think it has little clips on the plastic hoses and they either push in or pull out ,depends on what supplier delivered the parts to the assembly line at that point in time .It may even pay to renew these as well as they invariable break when trying to remove them ,similar type fittings are used on some peugeot engines and citreons as well and i alway end up breaking these as well as the plastic goes brittle after time.Like the headlights go dull and need a polish ,dashboard splits and the plastic bumpers crack.watch your hands when working with these plastic components and they can rip your hands to pieces and i find its easier to araldite plastic components back together rather than have stitches or plasters on my hands .
Aug 21, 2011 | 2004 Jaguar S Type
Need to check my fuses. Can't locate the fuse box.
For Audi the fuse box is located on the left side of dashboard behind a plastic cover (for left hand steering wheel vehicle). On inner face of the plastic cover you will find the fuse diagram.
Aug 29, 2010 | Audi A6 Cars & Trucks
How do you remove inner tub to get to the outer tub of Fisher & Paykel gwl11
You need 2 people for this.. Unscrew plastic wingnut down the centre of the agitator.(2) undo 2 phillips head screws under little rubber covers just under lid at front top edge.(3)lift top of machine like a car bonnet,get someone to hold it up for you.(4)Unclip big round plastic ring on top of the bowl,you may find its attached with a spring at the front left hand corner,just lay the plastic ring over front of machine & let it hang.The bowl should just lift straight out.Be carefull,the outside of the metal bowl is like a cheese greater trust me! PS when you put it back together & you lower the top of the machine(make sure that little white plastic lever hanging down) the right hand rear go's outside the righthand rear of the tub NOT squashed on top.Its an out of balance lever & it needs to dangle outside of the bowl/tub right rear.GOOD LUCK!
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
I can't figure out how to change the left hand signal bulb or the right hand brake light.
Open the trunk and you should see a round plastic circle inside on where the taillight would be. Gently pry it open. Inside there is like a plastic screw / knob that you need to unscrew. After this take a very fine flat screw driver (or a prying tool made of hard plastic would be better) and put it on the sides of the tail lights and gently start prying as there are some clips holding it down. Should be four clips, two on each side of the light near the halfway point
Sep 17, 2009 | 2001 Volkswagen Beetle
Hour-hand fell off clock
Plastic clock glasses are fitted on clocks in two different ways:
1) Clip-on plastic glass;
Check carefully all around the plastic glass and find where the clips are positioned. Insert the screwdriver between the glass and clock bezel and use the lever action to unclip it. Do the same to all clips following one by one till the glass come loose.
2) Glued plastic glasses;
Do exactly the same as described above, just this time go bit by bit all around the glass till it come loose.
NOTE: In both cases the plastic glass can crack if you are not expierenced in such an action! Start with ease and do not force that plastic glass too hard.
Rate me, please.
Mar 14, 2009 | Timex Watches
There is freezer burn on chicken in plastic packages
Hello
Welcome to Fixya
My name is Huum,
You need to use good freezer bags and not just plastic bags in the freezer.
And use these products witin six months..
When you put food into a plastic container for the freezer.
you need to burp the container.
That means to hold it with two hands and with one hand raise the corner of the lit a tiny bit while with the other hand you press down on the center of the lid and close the corner quickly so as to have burped out most of the air in the container. a little like a vacuum packed container.
So less air is in the container to cause condensation inside which is the frost you are getting
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 02, 2009 | Frigidaire Freezer Refrigeration White...
Delta TP300 Shopmaster 12-Inch Portable Planer Logo
62 people viewed this question
Top Delta Masonry Tools Experts
Vernon Taylor
Are you a Delta Masonry Tool Expert? Answer questions, earn points and help others
